Marlin for MKS Gen v1.3 upgrade September 30, 2015 01:03PM |
Re: Marlin for MKS Gen v1.3 upgrade October 01, 2015 05:54AM |
Re: Marlin for MKS Gen v1.3 upgrade October 02, 2015 08:19AM |
Re: Marlin for MKS Gen v1.3 upgrade October 04, 2015 10:31AM |
Re: Marlin for MKS Gen v1.3 upgrade October 10, 2015 05:52PM |
Re: Marlin for MKS Gen v1.3 upgrade October 13, 2015 04:07AM |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Marlin for MKS Gen v1.3 upgrade October 13, 2015 03:01PM |
Re: Marlin for MKS Gen v1.3 upgrade January 08, 2016 11:05AM |
Arduino: 1.6.7 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)" C:\XXX\Marlin.pde:44:101: fatal error: U8glib.h: No such file or directory #include // library for graphics LCD by Oli Kraus (https://code.google.com/p/u8glib/) ^ compilation terminated. exit status 1
Re: Marlin for MKS Gen v1.3 upgrade January 09, 2016 08:35AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Marlin for MKS Gen v1.3 upgrade January 09, 2016 12:13PM |
You need to install the u8glib into your arduino software (newbie basic issue).Quote
BearTechandTools
Can you elaborate the solution to the graphic controler problem?
I loaded Marlin onto mine and just hear a anoying sound from my LCD, but nothing visible is displayed. It stays black.
Same Firmware on a Ramps works flawless.
EDIT:
Also can't compile your firmware:
Re: Marlin for MKS Gen v1.3 upgrade January 09, 2016 01:29PM |
Okay hadn't this error yet. I'll sure be testing this!Quote
J-Max
Do a seach with the keyword in the wiki section of the reprap forum.
J-Max
The continuous beep with blue screen is because of the cable you use.
You need to invert one connector at the end of each cable. Simple as that. (Pin 1 should be Pin 20)
Re: Marlin for MKS Gen v1.3 upgrade January 09, 2016 02:10PM |
Re: Marlin for MKS Gen v1.3 upgrade January 10, 2016 05:41AM |
J-Max
You have to reverse one plug on each cable.
It's not a mistake, it's about the board and the cables.
If your marlin is for a CNC and not for a 3D printer, you don't need my modified Marlin.
Just upload your previous Marlin for Ramps to the MKS Gen. They are fully compatible.
The MKS Gen just have another mosfet output.
If you don't want to use that output, consider the MKS Gen as a regular Ramps board.
++JM
Re: Marlin for MKS Gen v1.3 upgrade January 10, 2016 05:58AM |
Re: Marlin for MKS Gen v1.3 upgrade January 10, 2016 06:02AM |
Re: Marlin for MKS Gen v1.3 upgrade February 12, 2016 02:53PM |
Re: Marlin for MKS Gen v1.3 upgrade February 13, 2016 10:45PM |
Re: Marlin for MKS Gen v1.3 upgrade February 23, 2017 04:37PM |
Re: Marlin for MKS Gen v1.3 upgrade February 25, 2017 04:37PM |
Re: Marlin for MKS Gen v1.3 upgrade June 22, 2017 12:48AM |
Re: Marlin for MKS Gen v1.3 upgrade June 27, 2017 08:48AM |
