G29 Command Results
Posted by codecad2015
G29 Command Results
December 25, 2015 05:29PM
I was trying to level my delta printer that uses Marlin firmware. Using Repetier-Host and connected to the delta printer,I sent the G29 V3 command and got the readouts Bed X: nnn Y:nnn Z: nnn.
What I don't understand are the numbers after the Z-probing was done, I know they're corrections but I don't know how to interpret and the equations used to calculated them. Z-probe tested 4x4 points.
Also, I wanted to use the "Bed Height Map" featured on Repetier V1.6.0 but it was grayed out. Any help is appreciated. Thanks!
Josh
Here's an example after Z-probing:
-0.22 -0.11 0.00 -0.19 -0.28 0.00
-0.11 -0.16 -0.21 -0.25 -0.35 0.00
0.00 -0.21 -0.28 -0.31 -0.43 0.00
-0.29 -0.30 -0.31 -0.35 -0.53 0.00
-0.53 -0.48 -0.43 -0.41 -0.55 0.00
0.00 0.00 0.00 0.00 0.00 0.00
Re: G29 Command Results
December 26, 2015 01:12AM
That is the Bed Topology Report. It looks like you are missing a lot of probe points. My guess is you have the Z-Probe on the right side of the effector. You have a some what dish shaped bed right now. Probably you should be adjusting your Delta_Radius. But all that is just a guess based on one set of numbers.
