Hi All,
I've reflashed a Megatronics 2.0 to the latest 1.1 Marlin and am trying to get my peripherals working again. It is hooked up to a VIKI I2C controller (LCD, Encoder, and SD slot). The display is working, but I'm having difficulty with the encoder and SD card. Neither are responding. I'm pretty sure I have to define the ENC_A, ENC_B, and SS pins for the firmware, but I haven't found the right spot or syntax to do it. For instance, I've tried adding "#define BTN_EN1 46 //ENC_A" and so forth to the Megatronics 2.0 pin config, but no luck.
I know the controller is wired to the Mega correctly as it worked before the reflash. (For context, the OEM (now out of business) never configured Marlin's temperature parameters very well for the printer (among other things), so I am working to improve it.)
Thanks for any help!
T
