Hello all,
I've bought a pretty cheap mini delta printer kit from China. I have assembled and configured Repetier firmware so mechanical operation is good.
I'm having troubles with the bed leveling and I will print glass table holders that will enable adjustment but for that I need to be able and print 1st.
I've used the calibration tool at this link: [
escher3d.com]
I get values (in steps) for offsets on the endstops. The thing is that I would like to have this implemented in software as turning the screws that hit the switched on the endstops requires constant re-checking and a long long time. Applying the suggested offsets from the calibration tool would save that time and will be accurate! The problem is I can't see where I can put that into the code and was hoping someone could guide me.
On top of it I have a problem homing as not all limit switches get released so i have 4mm "roll back" after hitting the switches to avoid problems.
Help will be appreciated!
