Z dual sensor and auto level probe
Posted by Natsu
January 10, 2018 02:02AM
I wonder if is possible with some firmware using 2 end stop's on separate Z motor (aka Z_DUAL_ENDSTOPS in Marlin FW) for G28 and using a sensor (inductive or whatever) con extruder block when using G29.
If some one already did that can just share the info or a link.
(I prefer to ask before change some code)
Tyvm
Re: Z dual sensor and auto level probe
January 10, 2018 11:56AM
Did you have a particular firmware or electronics board in mind?
It's possible to use dual Z endstop switches in RepRapFirmware too. However, the recommended approach is to use the Z probe to level the bed by adjusting the leadscrews independently instead. See [duet3d.com]. After that you can use G29 to do mesh bed compensation too if you wish.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
January 10, 2018 12:48PM
Usually, i work with ramps 1.4 and marlin for prototyping and experimenting, but can use also other firmware.
I will check in the code, must be not difficult to adapt if is not possible just by configuration and i post here results
January 10, 2018 12:53PM
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
//#define Z_MIN_PROBE_ENDSTOP
should invert commenting on those line maybe?
