serial pass through Protocol
July 28, 2012 07:37PM
Hello
i creates a custom firmware and i would use replicatorg with serial pass through driver
but i not found the protocol
I only find the FirmwareResponseProtocol [reprap.org]
but i need more information
you know where I can find the protocol?
thanks
Re: serial pass through Protocol
July 29, 2012 05:06AM
The closest there is to a protocol definition is here G-code For finer detail you need to look at the source code of your host and/or printer firmware.
July 29, 2012 07:36AM
I've put in a redirect, so this page now points directly to what bobc mentioned.
July 29, 2012 07:44AM
The truth is, the RepRap community simply refuses to define or respect anything which only vaguely looks like a standard. Developers do what they think is best at the time of writing the code and rarely look what others are doing. Newer slicers and hosts somewhat adapt to this model and allow to define different G-code flavours for each firmware.
So, to find out what the "protocol" is, you have to either try what other firmwares do, or to look into your hosts's source code to see what fits.
July 29, 2012 06:11PM
thanks for all reply
i did not understand why me test no work
but il why i used serialpassthrough and the protocol is for reprap5d
with reprap5d me firmware work fine
