Re: Project: FiveD on Arduino November 14, 2010 03:31PM |
Thanks that worked. I am now able to make and make program without errors. However when I try to run ./sender.sh I get these errors:Quote
This happens if you leave 'GEN3' defined, as the GEN3 electronics use pins (and uarts) that don't exist on a '168. I think it's defined both in the Makefile and in config.h at the moment- I probably should fix that.
Re: Project: FiveD on Arduino November 14, 2010 03:38PM |
Re: Project: FiveD on Arduino November 14, 2010 06:32PM |
if ((current_position.X != dda->endpoint.X) && (x_min() != dda->x_direction)) {
I will test tomorrow and see if I get any problems, of movement. Also I will look on signal using oscilloscope.|
Re: Project: FiveD on Arduino November 14, 2010 08:17PM |
Re: Project: FiveD on Arduino November 15, 2010 06:49AM |
( cat <&3 & cat >&3; kill %! ; ) 3<>/dev/arduinofor a super simple talker. set port up with stty first, see func.sh for more thoroughly tested examples
Re: Project: FiveD on Arduino November 15, 2010 06:57AM |
Re: Project: FiveD on Arduino November 15, 2010 11:39AM |
Re: Project: FiveD on Arduino November 15, 2010 12:06PM |
Re: Project: FiveD on Arduino November 15, 2010 01:15PM |
Re: Project: FiveD on Arduino November 15, 2010 08:39PM |
Re: Project: FiveD on Arduino November 16, 2010 03:38PM |
Re: Project: FiveD on Arduino November 16, 2010 04:13PM |
Re: Project: FiveD on Arduino November 16, 2010 04:19PM |
Re: Project: FiveD on Arduino November 16, 2010 06:56PM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: Project: FiveD on Arduino November 18, 2010 10:04AM |
Re: Project: FiveD on Arduino November 18, 2010 11:25AM |
Re: Project: FiveD on Arduino November 18, 2010 01:47PM |
Re: Project: FiveD on Arduino November 18, 2010 06:34PM |
Re: Project: FiveD on Arduino November 19, 2010 04:46AM |
Re: Project: FiveD on Arduino November 19, 2010 10:16AM |
Re: Project: FiveD on Arduino November 19, 2010 10:25AM |
// G28 - go home
case 28:
if (next_target.seen_X)
zero_x();
axisSelected = 1;
if (next_target.seen_Y)
zero_y();
axisSelected = 1;
if (next_target.seen_Z)
zero_z();
axisSelected = 1;
if (next_target.seen_E)
zero_e();
axisSelected = 1;
if(!axisSelected)
zero_x();
zero_y();
zero_z();
startpoint.F = SEARCH_FEEDRATE_X;
break;
// G92 - set home
case 92:
/* wait for queue (all movements) to complete */
for (;queue_empty() == 0
startpoint.X = current_position.X = 0;
axisSelected = 1;
startpoint.Y = current_position.Y = 0;
axisSelected = 1;
startpoint.Z = current_position.Z = 0;
axisSelected = 1;
startpoint.E = current_position.E = 0;
axisSelected = 1;
if(!axisSelected)
startpoint.X = current_position.X = \
startpoint.Y = current_position.Y = \
startpoint.Z = current_position.Z = \
break;
Re: Project: FiveD on Arduino November 19, 2010 02:08PM |
Re: Project: FiveD on Arduino November 21, 2010 03:24AM |
Re: Project: FiveD on Arduino November 22, 2010 07:10AM |
Re: Project: FiveD on Arduino November 23, 2010 07:00AM |
Re: Project: FiveD on Arduino November 24, 2010 12:14PM |
Re: Project: FiveD on Arduino November 30, 2010 04:55AM |
while ((c = format[i++])) {
if (j) {
switch(c) {
case 'l':
j = 4;
if (j) {
switch(c) {
case 'l':
j = 4;
break;
Re: Project: FiveD on Arduino November 30, 2010 11:01AM |
case 104:
temp_set(next_target.P, next_target.S);
if (next_target.S) {
enable_heater();<= id add this.
power_on();
else {
disable_heater();
break;
#define TEMP_THERMISTOR
#define TEMP_PIN_CHANNEL AIO0_PIN
#define ANALOG_MASK MASK(TEMP_PIN_CHANNEL)
#define NUM_TEMP_SENSORS 1
#ifdef TEMP_C
struct {
uint8_t temp_type;
uint8_t temp_pin;
uint8_t heater_index;
} temp_sensors[NUM_TEMP_SENSORS] =
// type pin heater
{ TT_INTERCOM, 0, 1 }
#endif
#define NUM_HEATERS 1
// #define HEATER_SANITY_CHECK
#ifdef HEATER_C
struct {
volatile uint8_t *heater_port;
uint8_t heater_pin;
volatile uint8_t *heater_pwm;
} heaters[NUM_HEATERS] =
// port pin pwm
{ &PORTD, PIND6, &OCR0A }
Re: Project: FiveD on Arduino November 30, 2010 11:15AM |
Re: Project: FiveD on Arduino December 01, 2010 07:48PM |
