Re: Project: FiveD on Arduino December 20, 2010 03:36AM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Project: FiveD on Arduino December 20, 2010 07:01AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: FiveD on Arduino December 22, 2010 04:29PM |
Re: Project: FiveD on Arduino December 22, 2010 06:26PM |
Felix
Re: Project: FiveD on Arduino December 26, 2010 05:26PM |
Re: Project: FiveD on Arduino December 26, 2010 10:23PM |
Re: Project: FiveD on Arduino December 27, 2010 04:24PM |
Re: Project: FiveD on Arduino December 27, 2010 07:13PM |
Re: Project: FiveD on Arduino December 27, 2010 09:56PM |
Re: Project: FiveD on Arduino December 28, 2010 07:54AM |
Re: Project: FiveD on Arduino December 28, 2010 03:26PM |
Re: Project: FiveD on Arduino December 29, 2010 05:33AM |
G1 X10 F600
G1 Z1 F20
it will attempt to "deaccelerate" from F600 to F20 in 1mm of Z movement, which is of course going to cause problems. Come to think of it, this feature sounds like a dead ringer for your problem. If you don't want to disable acceleration in the firmware, you could try adding a dummy low-feedrate move before each Z move.
Re: Project: FiveD on Arduino December 29, 2010 02:49PM |
Re: Project: FiveD on Arduino December 29, 2010 10:59PM |
Re: Project: FiveD on Arduino December 29, 2010 11:09PM |
Re: Project: FiveD on Arduino December 29, 2010 11:18PM |
Re: Project: FiveD on Arduino December 30, 2010 07:33PM |
Re: Project: FiveD on Arduino December 31, 2010 10:20AM |
Re: Project: FiveD on Arduino January 01, 2011 02:59PM |
Re: Project: FiveD on Arduino January 01, 2011 05:20PM |
Re: Project: FiveD on Arduino January 02, 2011 06:50PM |
Re: Project: FiveD on Arduino January 03, 2011 05:42AM |
However, after reading this thread I get the impression that the firmware is almost but not quite ready to use with the reprap host software.
So, is the firmware currently capable of running a reprap in conjunction with the reprap host software or should I plan on using the floating point based fived for arduino mega until this firmware is complete?
Re: Project: FiveD on Arduino January 03, 2011 10:04PM |
Re: Project: FiveD on Arduino January 04, 2011 05:28AM |
Re: Project: FiveD on Arduino January 04, 2011 07:21PM |
Re: Project: FiveD on Arduino January 04, 2011 07:25PM |
Re: Project: FiveD on Arduino January 04, 2011 07:53PM |
Re: Project: FiveD on Arduino January 05, 2011 04:58AM |
repsnapper send "\r\n" after the code line. fair enough thats normal.
5D checks to see if it has a 10 || 13 and processes the new line. problem is it reads 10 then processes the line as it is reading the 13 char which screws everything up when it comes around to check and tries to reprocess the line which may or may not be all there and blows up.
I could not see where this code originally keeps lines in the dda queue in order especially if there was a checksum error. so I have it doing that now.
can anyone who has done the work in their config tell me what they have their STEPS_PER_MM and MAXIMUM_FEEDRATE are set at?
Re: Project: FiveD on Arduino January 05, 2011 11:20AM |
Re: Project: FiveD on Arduino January 06, 2011 12:51AM |
