Re: New experimental firmware: all kinematics in host June 22, 2018 08:16AM |
Re: New experimental firmware: all kinematics in host June 30, 2018 02:29PM |
Re: New experimental firmware: all kinematics in host July 01, 2018 08:34AM |
MarkLogan
Kevin - I got a new extruder so needed to update my extrusion steps. I took the opportunity to update to the latest Klipper. Seemed to be working fine after the update. I did an 20mm XYZ cube and noticed my X and Y were a little long so I went back and recalculated the steps for them. I changed the X and Y steps and restarted and suddenly my square was way off. If you consider front/left as origin, the cube was drawn from left to right. That front face went back a bit so it was say 1mm back by the time it hit the corner. Same thing for the right side - from where it started to where it ended, it moved 'left' about 1mm. Reverse was true for back and right sides. So I ended up with a parallelogram. I played with the x and y steps some more and it was worse. Printed something bigger and the effect was even more pronounced. I went back to my original steps and it was 'almost' right - probably like its always been honestly and I just never noticed. Trouble is that I'm .2 to .4mm out in each direction on a 20mm square now. So I guess my question is: Would changing the steps for X and Y to different values (and different from each other) create that effect or is something else going on? I did some hardware troubleshooting and I can't find anything, and other than the extruder nothing has changed on the printer in a long time. Thoughts?
Re: New experimental firmware: all kinematics in host August 05, 2018 07:05AM |
Re: New experimental firmware: all kinematics in host August 06, 2018 10:54AM |
Re: New experimental firmware: all kinematics in host August 09, 2018 08:50PM |
Re: New experimental firmware: all kinematics in host September 01, 2018 03:14PM |
Re: New experimental firmware: all kinematics in host September 01, 2018 10:56PM |
Re: New experimental firmware: all kinematics in host September 02, 2018 11:03AM |
Re: New experimental firmware: all kinematics in host September 02, 2018 11:05AM |
SEA
Hi KevinOConnor,
I tried to connect display 12864 anet3d (aka RepRap Discount Mini graphical controller) with Tevo Tarantula (MKS Base 1.4)
I used UC1701 configuration, but it seems not yet implemented.
I assume it is planned. If so, when I can expect it to be done?
Anonymous User
Re: New experimental firmware: all kinematics in host September 08, 2018 02:33PM |
Re: New experimental firmware: all kinematics in host September 09, 2018 10:51AM |
Dimitar
Just experienced another issue with Klipper:
MCU 'mcu' shutdown: Rescheduled timer in the past
This generally occurs when the micro-controller has been
requested to step at a rate higher than it is capable of
obtaining.
Running Klipper on Arduino Mega2560, it is an old file I printed before with another firmware. I do not remember what the slicer settings were, but do not think that the speed goes above 120 mm/s (95K steps/sec).
Anonymous User
Re: New experimental firmware: all kinematics in host September 09, 2018 11:53AM |
Anonymous User
Re: New experimental firmware: all kinematics in host October 24, 2018 02:15PM |
Re: New experimental firmware: all kinematics in host October 28, 2018 11:40AM |
Re: New experimental firmware: all kinematics in host October 29, 2018 12:02PM |
Nitram
@KevinOConnor Is it possible to use an Arduino nano with an ATmega328P (old bootloader) as an aux-board
Re: New experimental firmware: all kinematics in host October 29, 2018 04:39PM |
Re: New experimental firmware: all kinematics in host December 10, 2018 12:58AM |
Re: New experimental firmware: all kinematics in host January 25, 2019 12:18PM |
Anonymous User
Re: New experimental firmware: all kinematics in host January 29, 2019 12:49PM |
Re: New experimental firmware: all kinematics in host January 29, 2019 03:33PM |
Re: New experimental firmware: all kinematics in host January 29, 2019 10:02PM |
Anonymous User
Re: New experimental firmware: all kinematics in host January 31, 2019 04:09AM |
