LPC1768/1769 Port of RepRapFirmware v3.1.x July 06, 2020 04:14PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 11, 2020 06:19AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 11, 2020 07:28AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 11, 2020 10:11AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 11, 2020 10:54AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 11, 2020 03:09PM |
gloomyandy
The WiFi is not MKS. it is a separate nodemcu module (ESP8266) that you hook up either using and adaptor board or make up your own wiring loom. It connects to the main board using SPI and the connection is pretty fast. The details are here: [github.com] not for everyone, but at least a couple of folks (in addition to me) have it working with the SBase.
Yep the download should take less than 80 seconds over WiFi it is only a couple of seconds or so (if that). SO I'm pretty sure that there is something not right, but your case seems much worse than others but I can't see anything wrong with how it is set up. I have my board hooked up to a router that supports 10/100/1000Mbit and it claims to have connected at 100Mbit.
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 14, 2020 07:34AM |
And the slow / fast decay pin is fixed and not externally accessible. Which leads to all kinds of problems.Quote
MKSA
The MKS in addition to be a pain with the Ethernet, uses 8825 stepper drivers soldered in place.
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 16, 2020 08:33AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 16, 2020 08:39AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 16, 2020 08:52AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 16, 2020 02:11PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 16, 2020 02:14PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 16, 2020 03:01PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 16, 2020 03:17PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 16, 2020 06:11PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 17, 2020 12:39PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 17, 2020 12:45PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 19, 2020 03:27AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x July 19, 2020 03:50AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x August 01, 2020 09:34AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x August 01, 2020 09:37AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x August 13, 2020 03:25AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x August 13, 2020 03:29AM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x August 21, 2020 05:58PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x August 30, 2020 02:20PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x August 30, 2020 03:40PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x August 31, 2020 01:02PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x August 31, 2020 01:08PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x September 01, 2020 04:17PM |
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x September 01, 2020 05:58PM |
