Teacup supported on Sanguinololu? October 02, 2011 05:09PM |
Re: Teacup supported on Sanguinololu? October 02, 2011 05:24PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Teacup supported on Sanguinololu? October 02, 2011 05:27PM |
Re: Teacup supported on Sanguinololu? October 02, 2011 05:35PM |
Re: Teacup supported on Sanguinololu? October 03, 2011 06:33AM |
Well I have to say I prefer Teacup hands down over Sprinter for many reasons.
Sanguinololu 1.1 config
Sanguinololu 1.2 config
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Teacup supported on Sanguinololu? October 03, 2011 01:37PM |
This would let people start with it working and they would not give up so fast.Quote
Should say
usable value for milling is 10 - 100
usable value for RepRap is 500 - 2000
And set the default value 1000 (same as sprinter)
Re: Teacup supported on Sanguinololu? October 03, 2011 02:44PM |
Re: Teacup supported on Sanguinololu? October 03, 2011 11:23PM |
Re: Teacup supported on Sanguinololu? October 03, 2011 11:35PM |
Re: Teacup supported on Sanguinololu? October 04, 2011 06:53AM |
Y_MIN_PIN should actually
> actually DIO19, not DIO16.
My bad. @ Traumflug please update.
Any reason why I should use the gen7 branch with combined enable pins?
Re: Teacup supported on Sanguinololu? October 04, 2011 07:05AM |
I mean, the idea to #define just X_ENABLE_PIN and not the other ones isn't that bad.
Re: Teacup supported on Sanguinololu? October 04, 2011 02:18PM |
Re: Teacup supported on Sanguinololu? October 04, 2011 02:25PM |
2) The default acceleration Value and recommended values.
Re: Teacup supported on Sanguinololu? October 04, 2011 02:38PM |
> 2. The MAXIMUM_FEEDRATE values are
> absurdly low for mm/min. For example, the default
> value of 200 for the X and Y axes translate to a
> maximum speed of 3.3 mm/sec.
Re: Teacup supported on Sanguinololu? October 05, 2011 04:57AM |
Re: Teacup supported on Sanguinololu? October 05, 2011 05:50AM |
Sprinters defaults
float max_feedrate[] = {200000, 200000, 240, 500000};
float homing_feedrate[] = {1500,1500,120};
Re: Teacup supported on Sanguinololu? October 05, 2011 08:39AM |
Re: Teacup supported on Sanguinololu? October 05, 2011 03:09PM |
Re: Teacup supported on Sanguinololu? June 05, 2012 12:03AM |
Re: Teacup supported on Sanguinololu? June 05, 2012 07:54AM |
Re: Teacup supported on Sanguinololu? June 06, 2012 01:45AM |
Re: Teacup supported on Sanguinololu? June 06, 2012 04:36AM |
Is there some way to turn on automatic temperature updating for the Hotend and Bed when they are on?
Re: Teacup supported on Sanguinololu? June 08, 2012 09:35PM |
Re: Teacup supported on Sanguinololu? June 09, 2012 07:27AM |
I have had troubles with numerous things in the control panel
No bed thermostat reading (it has a good connection to called out pin)
Extruder stepper turns only in one direction regardless of direction chosen
What should I use as a g code creator?
And what goes code commands the extruder to move?
