I have updated the files on thingiverse with a new version that parametises the tooth profile. This profile is 'subtracted' from a blank pulley to make the pulley teeth, and is more accurately the right shape of the belt teeth. It can also be adjusted for XL belting as well as T5. Full details on the thingiverse page.
There is a subtle difference between the teeth of the 'classic' pulley and this new version. The 'classic' teeth are a little longer and thinner, but the ramp angle of the tooth is incorrect. The new version has a very accurate profile, but isn't as deep as the old version, though should actually be a better fit and have more belt tooth in contact with the pulley tooth. I have yet to build an axis with them, so I'm not sure if this will cause any problems. There may be a tiny amount of pulley lash with the old version; the new version is tuneable to eliminate this, or increase it if you go a bit over the top with the numbers! Or just buy metal pulleys...
