I bought a partly built Mendel through ebay it came today.
The z-axis belt fits fine and the y-axis belt has already been fitted when it came but the x-axis belt is a good 8cm too long. I was thinking that I got the z and the x the wrong way around but the z fits perfectly.
Do I need to cut the belt and cut a few cm out then put where I have cut it in the grips that are attached to the extruder.
Just want to make sure before I cut a perfectly good belt.
EDIT: Also for the power supply do I need to get just a random plug and cut off the connector end and split the wires to put into my 'switching LED PSU'?
Thanks
Edited 1 time(s). Last edit at 09/12/2011 02:01PM by mapexmbirch.
