Hey so I have reciently completed the building process of my RepRap Prusa i2 but I have run into a couple different problems when trying to move around / calibrate my motors. First of all I was running in to an issue with my Z axis motor going backwards but I fixed that by just flipping around the connector. Im wondering if my Y motors is moving in the right direction, If I Click + on Pronterface it moves towards me (towards the motor end of the Y axis) do I need to change this aswell?
Now Im also have issues with the endstops and homing... When ever I click the Home button for any of the printers in Pronterface It moves the respected carriage away from the endstop (the Z axis moves down towards the heating bed) and it crashes against the bars at the other end and grinds there for a while until backing up about 1mm. I have tried messing with the firmware to fix this to no avail. Even with the Z axis after I hit the home button it will travel all the way towards the heating bed and hit the machanical endstop but still not stop moving downwards.
I am running Marlin firmware on a Printrboard and these are my current settings:
Any Help would be Awesome!!!
// Endstop Settings
//#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
const bool Y_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
const bool Z_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
#define DISABLE_MAX_ENDSTOPS
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X true
#define DISABLE_Y false
#define DISABLE_Z true
#define DISABLE_E false // For all extruders
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops true //If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true //If true, axis won't move to coordinates greater than the defined lengths below.
#define X_MAX_LENGTH 180
#define Y_MAX_LENGTH 180
#define Z_MAX_LENGTH 140
// The position of the homing switches. Use MAX_LENGTH * -0.5 if the center should be 0, 0, 0
#define X_HOME_POS 0
#define Y_HOME_POS 0
#define Z_HOME_POS 0
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {50*60, 50*60, 50, 0} // set the homing speeds (mm/min)
