@ Waitaki: ok I'll check out the Z-axis end-stop today... sure hope its as simple as the end-stop failing. As I was so close to final calibrations.
Actually this might make sense as I had to remove the end-stop the other day to add 2 Z-axis aluminium couplers... After changing the standard rubber tubes couplers I had to shave of some of the coupler mounting clamp plastic so the aluminium coupler won't rub on against the plastic clamp.
[EDIT] ok.. so to test the switch I simply swapped it over for the y-axis switch & hit home on the z-zxis & pushed the switch in & it worked.
One of the soldered wires looked a little dodgy so I re-soldered it & now all is good
Thanks for bringing this to light ... as simple as it sounds one can easily overlook the obvious.
Edited 2 time(s). Last edit at 09/09/2013 07:59AM by Mickman.
