So my i3 is nearly complete. I'm waiting on a part and meanwhile investigating cooling, and I've ended up a touch confused.
1 - Cooling ramps 1.4 - no problem. Obvious, and I've installed an 80mm silent fan cooling the stepper drivers and blowing away from the bed/head. No problem.
2 - Cooling the print - I've read that with some prints you need to cool your work as it prints, avoiding cooling the actual bed or head, which you want hot. - This makes sense, particularly with overhangs etc. I'm assuming this is the software controlled fan (D9 on the RAMPS) - i.e. the printing/slicing software controls this fan, switching it on where needed? I'm seeing a 40mm fan is the most common choice. Does this all sound right - .?
3 - Cooling the J-head. I've noticed that pretty much everyone seems to have a fan installed cooling their J-head. Some research suggests this is to cool the plastic (PEEK?) part so a) it doesn't melt when printing ABS, and b) so it doesn't jam when printing PLA. Is this right? Does PLA melt so easily that it can soften and block the head before it reaches the metal part? Are 30mm fans the way forward for this? Do you just connect it to permanent 12v? (some seem to piggy back off the heater wires)
Cheers
Roger
