Hello everyone,
I would like to replace my Z end-stop mechanical switch with an optical one and I found some extremely well built switch circuits on eBay. The only issue is instead of acting like the mechanical switch draining the sense voltage to ground it puts out +5v when the beam is broken. In order to switch the logic I think I need to change the value:
const bool X_ENDSTOPS_INVERTING
in the file configuration.h from false to true.
Is this the only value that needs to be changed or is this the correct one at all?
Thanks guys!
MakerFarm Prusa Mendel
-PrintR Board
-Z Stabilizers
-Greg's Accessible Extruder
-Mk1 Heatbed under Glass using ABS Slurry
-J-Head Mk IV-B Hot End 0.35mm
-3MM ABS Filament being used.
