Bed heating message
Posted by john golder
Bed heating message
April 04, 2015 04:15PM
Hi guys, I am new to forums in general as I can normally muddle through, but am getting desperate now, hope you can help.
I have a BQ Prius i3 Hephestos, which I have a few traumas with but I will update you later. I have finished the construction of my printer and it all appears to be ok.
My current problem is a message I get when I have selected the file I want to print from the SD card. Everything is loaded up, I select my file then a 'Bed Heating' message appears, but I don't have a heated bed.
I have messed around with various settings to no effect so I am guessing I may need to do something with the Ramp board.
Can anyone help, it will be much appreciated.
Best regards
John
Re: Bed heating message
April 04, 2015 05:39PM
What are you using to slice the models?
In Cura have you unchecked "Machine" -> "Machine Settings" -> "Heated Bed"
In Slic3r "Filament Settings" -> "Bed" set to 0
Steve
My updated Instructable on our Prusa i3 Build
[www.instructables.com]
April 05, 2015 10:09AM
Sorry Steve I am using Cura. John
April 06, 2015 02:38AM
Hi Steve, sorry it seems my last message was not posted!!!???
Using Cura
As far as I can tell I have unchecked all boxes and set to zero all that I can but no difference.
I have connected my laptop but the printer is not showing at the USB port, putting the SD card in shows the files available but still won't print them.
Is there a way of synchronizing the printer with the laptop?
Thanks
John
April 06, 2015 02:45PM
Did you set the thermister type to 0 in Marlin?
#define TEMP_SENSOR_BED 0
Steve
April 06, 2015 04:20PM
Hi Steve, the answer is no, I think, I can't find any thermistor settings.
You will have to tell me how to do this, I'm not too savvy with this sort of thing.
Thanks
John
April 08, 2015 02:47AM
john golder
Thanks
John
It's a firmware setting in Marlin's configuration.h file which you upload to the Arduino/RAMPS or similar.
If your printer board came pre-loaded then that should have been set by the kit maker.
Steve
