gregs configuration.scad setup questions
Posted by 6of1
July 28, 2012 04:05AM
I'm getting ready to print up [www.thingiverse.com] & [www.thingiverse.com]
I got the newest files from Gregs [github.com]
But now I'm a bit confused. At this time I have 2 questions (sure to be more)
1. I am using SAE vitamins (5/16" smooth & 1/4" ACME) with my SAE Prusa v2 kit from makerfarm. In Gregs "configuration.scad" I see:
// PLEASE SELECT ONE OF THE CONFIGURATIONS BELOW
// BY UN-COMMENTING IT
// Uncomment for metric settings
// METRIC METRIC METRIC METRIC METRIC METRIC METRIC METRIC
include metric.scad;
// Uncomment for imperial settings
// IMPERIAL IMPERIAL IMPERIAL IMPERIAL IMPERIAL IMPERIAL IMPERIAL
//include sae.scad;
But there is no "sae.scad" on his github page?
2. I also have GT2 belt and pulley setup. In gregs "configuration.scad" there is:
//T5:
belt_width=6;
belt_thickness=1.5;
tooth_height=1.5;
tooth_spacing=5;
////MXL:
//belt_width=4;
//belt_thickness=0.6;
//tooth_height=0.6;
//tooth_spacing=0.08*25.4;
I have GT2 belts, can I just create a new set for GT2 like:
//GT2:
belt_width=6;
belt_thickness=;
tooth_height=;
tooth_spacing=2;
If so, could someone tell me what to measure for the belt_thickness & tooth_height.
I'm guessing it would be (total_thickness - valley_thickness = tooth_height)
example:
(total belt thickness = 1.65mm) minus (valley thickness = 1.20mm) equals (tooth height = 0.45mm)
Re: gregs configuration.scad setup questions
June 20, 2013 02:28PM
6of1
Did you ever find the sae.scad?
Could someone point to it?
Thanks
June 20, 2013 05:30PM
//sae.scad
// PRUSA Mendel
// Default imperial sizes
// GNU GPL v2
// Josef Průša
// josefprusa@me.com
// prusadjs.cz
// [www.reprap.org]
// [github.com]
//[raw.github.com]
// DONT CHANGE THIS FILE! ALTER VALUES IN CONFIGURATION.SCAD INSTEAD
// RODS
threaded_rod_diameter = 9;
threaded_rod_diameter_horizontal = 9;
smooth_bar_diameter = 9;
smooth_bar_diameter_horizontal = 9;
// Nuts and bolts
m8_diameter = 9;
m8_nut_diameter = 15.7;
m4_diameter = 5.5;
m4_nut_diameter = 10.6;
m3_diameter = 5.5;
m3_nut_diameter = 10.6;
// Bushing holder
bushing_core_diameter = smooth_bar_diameter;
bushing_material_thickness = 1;
