The plate is expecting you to use 3 linear bearings, two on one side, one on the other. In this case, less is more because...
* Three linear bearings means less friction in your y-movement.
* It's easier to calibrate three points into a flat plane than four.
* Spare linear bearing. (Use the smoothest bearings, and don't use the others.)
I went from the Wiki's two-plate solution to a single plate like you've got. The photos there might be instructive, if the text above isn't clear. [
plus.google.com]
Edited 1 time(s). Last edit at 06/10/2013 04:50PM by Karmavore.
