Thermostat on Hot End
Posted by tivkin
June 17, 2013 11:38AM
How close does the the thermostat element need to be to the heat end? I saw an online video showing it attached with shrink wrap/tape where the hot end element is soldered to the wire. I copied that, but wanted to make sure.
Here is a pic of how I assembled it; [geotrinket.com]
Edited 1 time(s). Last edit at 06/17/2013 11:39AM by tivkin.
Re: Thermostat on Hot End
June 21, 2013 10:56AM
It should go in that hole. I put a dab of muffler cement in the hole (same as you might use for the resistor), then carefully bend the leads so the bend is just above flush with the brass when inserted, then tape around the entire brass (resistor leads and all) 4-5 loops of Kapton for securing the heater and insulation. Some people do this with thermal grease, but I find that the grease creeps into the tape over time and ruins the adhesive. You can just put it in dry, but the response time won't be as good. Either way, secure the leads well (I use more Kapton + strain relief the wire with a zip tie further up the barrel) as the heater and thermistor wires can be fragile.
