Trouble with carve/width over carve/thickness ratio - please help October 05, 2011 03:58PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 05, 2011 05:18PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 05, 2011 06:05PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 05, 2011 08:18PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 06, 2011 03:27AM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 06, 2011 03:36AM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Trouble with carve/width over carve/thickness ratio - please help October 06, 2011 06:11AM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 06, 2011 10:53AM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 06, 2011 02:29PM |
Flakster
Craft Section of Skeinforge
Plug in: Bottom
Activate Bottom –– Yes
Additional height over layer thickness (ratio) - 0.7
Altitude (mm) - 0.0
SVG viewer - webbrowser
Plug in: Carve
Add layer template to SVG – Yes
Extra decimal places (float) - 2.0
Import coarseness (ratio) - 1.0
Infill in direction of bridge – Yes
Layer thickness (mm) - 0.4
-Layers-
Layers from (index) 0
Layers to (index) 912345678
Mesh type – "correct mesh"
Perimeter width over thickness (ratio) 1.8
SVG viewer webbrowser
Plug in: Chamber
Activate chamber – No
Plug in: Clip
Activate clip – No I find this one is important to have turned on
Clip over perimeter width (ratio) - 0.5
Maximum connection distance over perimeter width (ratio) - 10.0
Plug in: Comb, Cool I also find Comb is important to have on
Activate – No
Plug in: Dimension
Activate dimension – Yes
Absolute extrusion distance – Yes
Extruder retraction speed (mm/s) - 30.0
-Filament-
Filament diameter (mm) - 1.85 (measured with digital calipers)
Filament packing density (ratio) - 1.0
Minimum Travel for Retraction (millimeters) - 1.0
Retract Within Island - False
Retraction distance (mm) - 3.0 This is too high and will cause blobs because the head stays in one spot to long. For a direct drive extruder (Mendel / Prusa) a distance of 0.2 - 1.0 is enough. (start with 0.5)
If its a Bowden cable extruder (Huxley/Ultimaker) its 0.5 - 2.0 (start with 1.0)
Restart extra distance (mm) - 0
Plug in: Export
Activate export – Yes
Add export suffix – Yes
Gcode small – Yes
Plug in: Fill
Activate fill – Yes
-Diaphragm-
Diaphragm period (layers) - 999999
Diaphragm thickness (layers) - 0
-Extra shells-
Extra shells on alternating solid layer (layers) - 0 Its good to have 1 extra shell unless printing gears
Extra shells on base (layers) - 0 Its good to have 1 extra shell unless printing gears
Extra shells on sparse layer (layers) - 0 Its good to have 1 extra shell unless printing gears
-Grid-
Grid circle separation over perimeter width (ratio) - 0.2
Grid extra overlap (ratio) - 0.1
Grid junction separation band height (layers) - 10
Grid junction separation over octagon radios at end (ratio) - 0.0
Grid junction separation over octagon radios at middle (ratio) - 0.0
-Infill-
Infill begin rotation (degrees) - 45.0
Infill begin rotation repeat (layers) - 1
Infill odd layer extra rotation (degrees) - 90.0
Line – Yes
Infill perimeter overlap (ratio) - 0.2
Infill solidity - (this gives the % fill ratio in the middle layers) – currently 1.0 (100%) To high unless printing gears
Infill width over thickness (ratio) - 1.8
Solid surface thickness (layers) - 1 Its almost impossible to get a good surface with this set to one. Try 3
Plug in: Fillet, Home, Hop, Inset, Jitter, Lash
Activate – No
Plug in: Limit
Activate limit – Yes
Maximum initial feed rate (mm/s) - 40.0
Plug in: Multiply
Activate multiply – Yes
-Centre-
Centre X (mm) 100
Centre Y (mm) 100
-Number of cells-
Number of columns (integer) 1
Number of rows (integer) 1
Separation over perimeter width (ratio) 15.0
Plug in: Oozebane
Activate oozebane – No
Plug in: Preface (can’t be turned off)
Set positioning to absolute – No
Set units to millimetres – No
Start at Home - No
Turn Extruder Off at Shut Down - No
Turn Extruder Off at Start Up - No
(I keep all these as "No" since I'd rather just have them in my own start.gcode file (or end.gcode))
(The start.gcode and end.gcode codes are kept in the Skeinforge alterations folder )
Plug in: Raft
Activate raft – Yes
Add raft, elevate nozzle, orbit – Yes
-Base-
Base feed rate multiplier (ratio) 1.0
Base flow rate multiplier (ratio) 1.0
Base infill density (ratio) 0.5
Base layer thickness over layer thickness 2.0
Base layers (integer) 0
Base nozzle lift over base layer thickness (ratio) 0.4
-Interface-
Interface feed rate multiplier (ratio) 1.0
Interface flow rate multiplier (ratio) 1.0
Interface infill density (ratio) 0.5
Interface layer thickness over layer thickness 1.0
Interface layers (integer) 0
Interface nozzle lift over interface layer thickness (ratio) 0.45
"Name of Support End File: support_end.gcode" (moved from Preface tab in earlier skeinforge versions)
"Name of Support Start File: support_start.gcode" (moved from Preface tab in earlier skeinforge versions)
-Object first layer-
Object first layer feed rate infill multiplier (ratio) 0.4
Object first layer feed rate perimeter multiplier (ratio) 0.4 This should be 1.0 since it is already lowered in the Speed tab
Object first layer flow rate infill multiplier (ratio) 0.4
Object first layer flow rate perimeter multiplier (ratio) 0.4 This should be 1.0 since it is already lowered in the Speed tab
Operating nozzle lift over layer thickness (ratio) 0.5
-Raft size-
Raft additional margin over length (%) 1.0
Raft margin (mm) 3.0
-Support-
Activate support cross hatch – No
(There's a few other settigs in the excel file for this plugin. I'm unsure if they appear on screen – need to update to reflect reality at some point. They are:
"Initial Circling: False"
"Infill Overhang over Extrusion Width (ratio): 0.05"
"Support Flow Rate over Operating Flow Rate (ratio): 1.0"
"Support Gap over Perimeter Extrusion Width (ratio): 1.0"
"None True"
"Empty Layers Only False"
"Everywhere False"
"Exterior Onl - False"
"Support Minimum Angle (degrees): 60.0"
Plug in: Scale
Activate scale – No
Plug in: Skirt
(prints a perimeter makes sure plastic is extruding and get things flowing nicely immediately before the 'real print')
Activate skirt – No (Actually only "no" for now – Once I have my wall thickness correct I'll turn back on)
Convex – Yes
Gap over perimeter width (ratio) - 10.0
Layers to (index) - 1
Plug in: Speed
Activate speed – Yes
Add flow rate – Yes
-Bridge-
Bridge feed rate multiplier (ratio) 1.0
Bridge flow rate multiplier (ratio) 1.0
-Duty cycle-
Duty cycle at beginning (portion) 1.0
Duty cycle at ending (portion) 0.0
Feed rate (mm/s) 40.0
Flow rate setting (float) 40.0
Orbital feed rate over operating feed rate (ratio) 0.5
Maximum Z feed rate (mm/s) - 1.0 - This used to be on the Limit plugin tab
-Perimeter-
Perimeter feed rate over operating feed rate (ratio) 0.4
Perimeter flow rate over operating flow rate (ratio) 0.39
Travel feed rate (mm/s) 50.0
Plug in: Splodge
Activate splodge – No
Plug in: Stretch
(Used to compensate for the fact that holes are printed smaller than they should be)
Activate stretch – Yes
Cross limit distance over perimeter width (ratio) - 5.0
Loop stretch over perimeter width (ratio) - 0.11
Path stretch over perimeter width (ratio) - 0.0
-Perimeter-
Perimeter inside stretch over perimeter width (ratio) - 0.32
Perimeter outside stretch over perimeter width (ratio) - 0.1
Stretch from distance over perimeter width (ratio) - 2.0
Plug in: Temperature
Activate temperature – Yes
-Rate-
Cooling rate (C/s) 3.0
Heating rate (C/s) 10.0
-Temperature-
Base temperature (C) - 200.0
Interface temperature (C) - 200.0
Object first layer infill temperature (C) - 200
Object first layer perimeter temperature (C) - 200
Object next layers temperature (C) - 185
Support layers temperature (C) - 185
Supported layers temperature (C) - 185
Plug in(s): Tower, Unpause, Widen, Wipe
Activate – No
My start code is
; The idea is to
; - Home all axes
; - zero all counters
; - Go to the dump zone and extrude some stuff to get things going
; - Start printing immediately after
; Note I don't set the extruder temperature or wait till it gets hot (for now), I do that manually
G21 ;Metric is good!
;Go HOME and set everything to zero
G28 ; Move to Home positions and zero all counters (positioning and extruder)
G90 ; absolute positioning
;Move UP 0.2 mm - This seems to be at the start of all generated gcode but I include it for safety's sake
G1 Z0.2 F90 This one seems unnecessary since the first gcode will have a height included.
; Go to dump zone and extrude stuff
G1 X135 Y0 F2000 ; Move to 0, 135 and set feedrate 2000
G1 E30 ; Extrude 30 mm of PLA This seems excessive. Unless you have a poor hotend (from experience)
G92 E0 ; Set the extruder position (counter) to 0
; And now we get printing ASAP
Re: Trouble with carve/width over carve/thickness ratio - please help October 06, 2011 11:04PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 06, 2011 11:45PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 07, 2011 12:11AM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 07, 2011 12:44AM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 07, 2011 03:19AM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 07, 2011 03:35AM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 14, 2011 07:44AM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 14, 2011 02:15PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 14, 2011 02:25PM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Trouble with carve/width over carve/thickness ratio - please help October 14, 2011 02:51PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 16, 2011 12:11PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 23, 2011 01:22AM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 25, 2011 03:24PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 25, 2011 04:17PM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 26, 2011 03:18AM |
Re: Trouble with carve/width over carve/thickness ratio - please help October 26, 2011 12:33PM |
