Can anyone explain the Skeinforge Bottom plug-in operates in simple terms to me?
I've read the manual (http://fabmetheus.crsndoo.com/wiki/index.php/Skeinforge_Bottom) but don't understand how it translates into practical advice about printer calibration. (Wiki manual wording at bottom of post)
I have drawn some (quite probably wrong) conclusions based on what I experience with it. I'd be interested in people's observations.
I decided (for no good reason at all and wrongly) that I could just turn Bottom off and it wouldn't affect my prints in an important way. However, I then noted that all my objects were approx 0.5mm short (no matter how tall – always approx 0.5mm never, say, 5% shorter). So, I turned it back on and the height was correct (more or less – obviously other Skeinforge settings are in play here too).
My Bottom settings are:
- Additional Height over Layer Thickness – 0.7 (note that my layer thickness in Carve plug-in is 0.3, in case that's important)
- Altitude - 0
I'm not using a raft.
This would mean the Wiki manual descriptive text translates (for me) to:
- No 'Additional' height – so ignore that.
- Take an 'additional height' of 0.7 (since I set that)
- Add the layer thickness (0.3 in this case, as provide by Carve/layer Height).Total = 1.0mm
<*** Or am I interpreting the word "over" here incorrectly – is it a division not an addition? ***>
- Multiply by the layer thickness (0.3 in this case, as provide by Carve/layer Height).
- Resulting in a final number of = 0.3mm
So, I guessing that the Bottom plug-in somehow (as I would want it to) raised my object height by 0.3mm ('approx 0.5mm') – i.e. it compensated for the fact that the height of my extruder nozzle when I begin a print is approx 0.3mm (according to feeler gauges & 'the thickness of 1 (or maybe 2) piece(s) of paper'?)
Does that sound right to anyone???
Cheers
Pete
p.s. Very hard to avoid bottom jokes in this post
Wiki Wording:
Default is half.
The layers will start at the altitude plus the 'Additional Height over Layer Thickness' times the layer thickness. The default value of half means that the bottom layer is at the height of the bottom slice, because each slice is made through the middle of each layer. Raft expects the layers to start at an additional half layer thickness. You should only change 'Additional Height over Layer Thickness' if you are manipulating the skeinforge output with your own program which does not use the raft tool.
Altitude
Default is zero.
Defines the altitude of the bottom of the model. The bottom slice has a z of the altitude plus the 'Additional Height over Layer Thickness' times the layer thickness."
