I've been having one persistent problem with my prints that I can't quite seem to be able to change at all, either for the better or the worse. I always get oozing at the 'lift up' corner - the corner of the print where the extruder pauses for a second to lift up the z-axis.
I can only see two settings in SFact that would seem to affect this blobbing. - Oozerate (mm/min) and Extruder Retraction Speed (mm/s). Are these the right settings to manipulate? What values would you recommend to change to help this problem?
I've also had a quick look at the daily branch of SFact, as it seems to have a lot more retraction options, under the dimension tab, but there I've got too many choices, and I don't know where to start!
Any suggestions would be greatly appreciated.
___________________________________________________________________________
systematictechnology.net
