I found in the documentation of sfact/skeinforge that you can use settings in your alterations: first of all there is only one example for the bed temperature.
and when I tried to use that in my start.gcode it does not replace it. it comes out as I entered it:
M140 S setting.chamber.BedTemperature
M104 S settings.temperature.BaseTemperature
G28
M190 S setting.chamber.BedTemperature
M109 S settings.temperature.BaseTemperature
G90
G21
G92 E0
(Edit: around the settings are those < brakets which are removed for some weird reason by this forum)
(yes the checkbox for Replace Variable with Setting is checked)
my second problem the code generated by sfact is partly redundant with mine.
the reason for my alteration of the start.gcode is that I find it very inefficiant(time consuming) waiting for the bed to heat up and than turn the heat for the nozzle on and wait again.
So if there is a fix for that, other than setting the temperature in printrun before starting the print or editing the gcode manually every time I would be happy to accept those selutions.
Edited 2 time(s). Last edit at 10/25/2012 08:49AM by Etherflash.
