Slicing failure February 01, 2013 03:57PM |
Dwindle procedure took 8 seconds. [[999, 10]] Oozestep procedure took 6 seconds. Alteration procedure took 1 second. Traceback (most recent call last): File "./skeinforge/skeinforge_application/skeinforge_utilities/skeinforge_craft.py", line 227, in main() File "./skeinforge/skeinforge_application/skeinforge_utilities/skeinforge_craft.py", line 224, in main writeOutput(' '.join(sys.argv[1 :]), False) File "./skeinforge/skeinforge_application/skeinforge_utilities/skeinforge_craft.py", line 135, in writeOutput return pluginModule.writeOutput(fileName, shouldAnalyze) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\export.py", line 301, in writeOutput replaceableExportGcode = selectedPluginModule.getOutput(exportGcode) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\export_plugins\static_plugins\gcode_small.py", line 38, in getOutput return GcodeSmallSkein().getCraftedGcode(gcodeText) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\export_plugins\static_plugins\gcode_small.py", line 77, in getCraftedGcode self.parseLine(line) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\export_plugins\static_plugins\gcode_small.py", line 85, in parseLine self.parseComment(line) AttributeError: GcodeSmallSkein instance has no attribute 'parseComment'
Re: Slicing failure February 02, 2013 07:12AM |
Re: Slicing failure February 03, 2013 09:44AM |
Traceback (most recent call last): File "./skeinforge/skeinforge_application/skeinforge_utilities/skeinforge_craft.py", line 227, in main() File "./skeinforge/skeinforge_application/skeinforge_utilities/skeinforge_craft.py", line 224, in main writeOutput(' '.join(sys.argv[1 :]), False) File "./skeinforge/skeinforge_application/skeinforge_utilities/skeinforge_craft.py", line 135, in writeOutput return pluginModule.writeOutput(fileName, shouldAnalyze) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\export.py", line 275, in writeOutput gcodeText = skeinforge_craft.getChainTextFromProcedures(fileName, procedures[: -1], gcodeText) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_utilities\skeinforge_craft.py", line 44, in getChainTextFromProcedures text = craftModule.getCraftedText(fileName, text) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\limit.py", line 61, in getCraftedText return getCraftedTextFromText( archive.getTextIfEmpty(fileName, gcodeText), repository ) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\limit.py", line 71, in getCraftedTextFromText return LimitSkein().getCraftedGcode(gcodeText, repository) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\limit.py", line 117, in getCraftedGcode self.parseLine( lineIndex ) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\limit.py", line 185, in parseLine line = self.getZLimitedLineArc(line, splitLine) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\limit.py", line 143, in getZLimitedLineArc return self.getZLimitedLine(deltaZ, distance, line, splitLine) File "D:\3D-basis\Software-master\skeinforge\skeinforge_application\skeinforge_plugins\craft_plugins\limit.py", line 128, in getZLimitedLine zFeedRateSecond = self.feedRateMinute * deltaZ / distance / 60.0 ZeroDivisionError: float division by zero
Re: Slicing failure February 04, 2013 02:55AM |
Re: Slicing failure February 04, 2013 09:47AM |
Re: Slicing failure February 04, 2013 10:55AM |
Re: Slicing failure February 17, 2013 06:08PM |
