Hi all,
I try to follow the howto of [
reprap.org] to create an outline for an etchable PCB. As software I use skeinforge, hence I skip the steps using blender.
My problem is that the outlines all have the wrong size. I think inkscape is putting the size into the svg in pixel units which are translated by skeinforge as milimeter (1 px : 1 mm). I do not know the correct ratio - or rather I do not know if I am doing anything wrong with Inkscape or did I stumble across a skeinforge bug?
If someone has some experience with the issue, I would be glad if I could get a clue.
Markus
