Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 02, 2011 01:34AM |
Admin Registered: 15 years ago Posts: 1,470 |
The Dimension plugin changed for skeinforge 40. You need to change your firmware e_steps_per_mm to steps per mm of feedstock, rather than steps per mm of extrudate. Also, you should have your flowrate and feedrate set to the same value. Then measure your feedstock diameter and input that, and the filament packing ratio for ABS should be about 0.85 and for PLA should be 1.0. Also, you'll need to change the extruder retraction speed, as that is now in mm/s of feedstock as well, so it should be much smaller than it was before. Same goes for retraction distance.
The whole idea is that now skeinforge knows how much plastic is going into your extruder, and therefore knows how much is coming out. Also, you won't have to adjust your firmware or the skeinforge settings when using different nozzle sizes.
I just spent the past couple hours figuring that all out, can you tell? I had to track back from [fabmetheus.blogspot.com] to a post on a different blog to figure out what was going on.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 02, 2011 04:59AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 02, 2011 08:44AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 02, 2011 12:31PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 02, 2011 02:29PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 02, 2011 07:13PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 03, 2011 12:45AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 03, 2011 05:49PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 03, 2011 07:01PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 03, 2011 11:11PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 05, 2011 01:21PM |
That's not too good of an idea. Ideally you want to be moving at the same speed that you are extruding. If you increase layer height but leave width over thickness the same, you have to increase flow rate more than feed rate, which causes squishing of the filament output. This makes overhangs and bridges really difficult, if not impossible, to print.Quote
brnrd
Why would you want to change the width over thickness ratio when you change layer height? I just leave it at 1.5 regardless on whether my thickness is 0.4 or 0.3 mm.
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 05, 2011 06:38PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 06, 2011 04:11PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 10, 2011 11:06PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 11, 2011 05:03AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 11, 2011 10:46AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 11, 2011 11:15AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 11, 2011 01:10PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 11, 2011 01:11PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 11, 2011 01:18PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 11, 2011 04:23PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 11, 2011 06:16PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 11, 2011 06:43PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 11, 2011 06:58PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 12, 2011 07:02AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 12, 2011 10:29AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 12, 2011 03:26PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 12, 2011 05:48PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 12, 2011 07:03PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 12, 2011 07:55PM |
