Suggestions for SF42 August 16, 2011 06:55PM |
Re: Suggestions for SF42 August 18, 2011 08:57AM |
Re: Suggestions for SF42 August 21, 2011 04:13PM |
Re: Suggestions for SF42 August 21, 2011 04:22PM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Suggestions for SF42 August 21, 2011 06:23PM |
I'll have to check that out.. I've been avoiding yet another slicer but have been hearing nice things about sfact..Quote
ahmetcemturan
- Support feed/flow should obey Object First Layer modifiers: in SFACT you can give a direct Feedrate and set flow seperately
When I do use a raft, not very often, I do also use interface..Quote
ahmetcemturan
- It'd be nice if support density was split from interface density. : Does anyone use interface? what is it good for?
I think that may be coming in SF42, too. Maybe. Hope so..Quote
ahmetcemturan
- A min travel distance before reversal kicks in would be nice. FACT has that
Wider would be fine, too.. And/or slower.Quote
ahmetcemturan
- Skirt is quite nice but I still don't always get a nice & primed extrusion.. Having multiple shells on skirt might be cool: Why not making it wider...
Re: Suggestions for SF42 August 21, 2011 06:26PM |
Re: Suggestions for SF42 August 23, 2011 02:44AM |
Re: Suggestions for SF42 August 23, 2011 04:09AM |
Re: Suggestions for SF42 August 24, 2011 05:13AM |
Re: Suggestions for SF42 August 25, 2011 07:18PM |
Re: Suggestions for SF42 August 26, 2011 02:27PM |
Re: Suggestions for SF42 August 29, 2011 07:37PM |
Re: Suggestions for SF42 September 03, 2011 07:13AM |
Re: Suggestions for SF42 September 03, 2011 04:14PM |
Re: Suggestions for SF42 September 06, 2011 06:46PM |
Re: Suggestions for SF42 September 07, 2011 04:25AM |
Re: Suggestions for SF42 September 07, 2011 10:04AM |
def getUnpausedMovement(self, distance, line, splitLine): "Get an unpaused movement." if distance <= 0.0: return line resultantReciprocal = 1.0 - self.delaySecond / distance * self.feedRateMinute / 60.0 resultantReciprocal = max(self.minimumSpeedUpReciprocal, resultantReciprocal) return self.distanceFeedRate.getLineWithFeedRate(self.feedRateMinute / resultantReciprocal, line, splitLine)
def getUnpausedMovement(self, distance, line, splitLine): "Get an unpaused movement." if distance <= 0.0: return line resultantReciprocal = self.delaySecond / distance * self.feedRateMinute / 60.0 resultantReciprocal = max(1.0, resultantReciprocal) return self.distanceFeedRate.getLineWithFeedRate(self.feedRateMinute / resultantReciprocal, line, splitLine)
Re: Suggestions for SF42 September 14, 2011 03:44PM |
Re: Suggestions for SF42 September 16, 2011 03:56AM |
Re: Suggestions for SF42 September 18, 2011 11:37PM |
Re: Suggestions for SF42 September 19, 2011 05:05AM |
Re: Suggestions for SF42 September 19, 2011 12:39PM |
Re: Suggestions for SF42 September 19, 2011 01:48PM |
Re: Suggestions for SF42 September 20, 2011 08:22PM |
Re: Suggestions for SF42 September 20, 2011 11:52PM |
Re: Suggestions for SF42 September 21, 2011 12:51AM |
Re: Suggestions for SF42 September 21, 2011 09:28AM |
