Sanguinololu 1.3a power supply?
Posted by gordon13
November 12, 2011 11:09AM
I am using Sanguinololu with a screw terminal for the power connection however Im not sure what power supply to use. The wiki says 12 volts but nothing about the current. It would need to power 5 stepper motors + the hot end. What power supply would I need to power this?
Re: Sanguinololu 1.3a power supply?
November 14, 2011 09:15AM
The cheapest option is to get a used computer power supply. You need ~ 2 amps per stepper, so 8 amps (z shares stepper driver), plus your hot end and bed if you use one. I would say ~10 amps bed and maybe ~5 amps for the hot end.
Here is a conversion guide:
[www.wikihow.com]
November 14, 2011 01:31PM
Ah thanks. I don't have a bed so total 13 amps. Finding a computer psu should be easy enough.
November 14, 2011 04:15PM
You want to make sure that it has enough power:
Watts = Amperage X Voltage
Watts = 13 Amps X 12 Volts
156 Watts
Anything not in a "minitower" size should give more than that. I think my newest PSU does 500W.
November 14, 2011 06:32PM
If I get a psu that supplies something like 300 watts will that cause any issues (ie too much amperage causing the whole thing to catch fire)?
November 15, 2011 09:16AM
No, just follow the guide and use a few of the yellow leads for 12V and a few black for ground. You will need a sandbar style resistor to hold a load to make sure the power save feature doesn't turn it off when low loads are present. An an on/off switch is also nice, but you can just plug or unplug it and join the green and black with a twist cap or solder.
November 15, 2011 09:28AM
Awesome. Thanks for the clarification.
November 26, 2011 10:58PM
Actually, the power required to run a printer without a HPB is 12V at 5A.
I use a laptop style 12v/5A power brick that I picked up off eBay for < $10 shipped to run my printer without the HPB. I've run it for dozens of hours like that since getting it about a month ago. It barely gets warm.
It's very much nicer, cheaper and smaller than a computer power supply, and it's totally silent.
The one I got plugs into a Radio Shack type N coaxial power jack (5.5mm x 2.5mm) and I posted a bracket on Thingiverse to hold one of them. It's pretty nice and clean.
November 27, 2011 06:58AM
Nice. Might try that in version 2.0 of my printer because the PC psu Im currently using is pretty big and noisy.
