Testing FTDI chip using USB COM port March 07, 2012 08:00AM |
[url=http://reprap.org/wiki/Sanguinololu#Soldering_the_FTDI
Sanguinololu page[/url]]
Now is a good time to test the FTDI chip. Plug a USB cable into the port. The device should show up as a COM port or a TTY device and allow it to be opened. If you temporarily connect the 'TX' and 'RX' pins on the USB2TTL port on the back of the board anything you type in your terminal application (such as PuTTy) should be echoed back to you.
Re: Testing FTDI chip using USB COM port March 07, 2012 08:45AM |
Re: Testing FTDI chip using USB COM port March 07, 2012 09:16AM |
Re: Testing FTDI chip using USB COM port March 07, 2012 10:32AM |
Re: Testing FTDI chip using USB COM port March 07, 2012 12:02PM |
