Soldered up a sanguinololu 1.3a.
Connected to laptop:
[2327231.947046] usb 8-5: new full-speed USB device number 46 using ohci_hcd
[2327232.117218] ftdi_sio 8-5:1.0: FTDI USB Serial Device converter detected
[2327232.117306] usb 8-5: Detected FT232RL
[2327232.117311] usb 8-5: Number of endpoints 2
[2327232.117314] usb 8-5: Endpoint 1 MaxPacketSize 64
[2327232.117318] usb 8-5: Endpoint 2 MaxPacketSize 64
[2327232.117322] usb 8-5: Setting MaxPacketSize 64
[2327232.120032] usb 8-5: FTDI USB Serial Device converter now attached to ttyUSB0
Fire up pronterface, cannot connect.
Fire up arduino 0022, cannot upload:
Binary sketch size: 57358 bytes (of a 63488 byte maximum)
avrdude: stk500_recv(): programmer is not responding
Later I put a usb memory in the laptop and nothing happened, tested in my stationary, works fine.
Tested another sanguinololuboard with my stationary computer, works fine, both uploading marlin and connecting.
Not that I have called Sherlock holmes, but it seems my laptop should be in usb quarantine.
Questions:
I bought a multimeter the other day, can I and if Yes, at what points should I measure if the "tracks" are ok?
I have also bought an
E'go USB-TTL adapter in case I just could solder that in. Being a software guy, I thought I should ask first, so that I don't make it worse.
Please, help.
Thanks in advance!
