Lack of bypass/decoupling Capacitors on Sanguino
Posted by dshay
December 05, 2012 09:33PM
I would highly suggest anyone who purchases a Sanguino to install a .1uF ceramic capacitor between Power and Ground on the board, it's really easy to do because on the Atmega644 DIP they're right next to each other.
I've attached documentation from Atmel, the manufacturer that would substantiate my suggestion.
A cap like the following would do the trick...
478-4855-ND
http://www.digikey.com/product-detail/en/SR201C104KAR/478-4855-ND/1550773
This cap should be placed, per the mfg, as close to the power and ground pins as possible. It's easy to solder them on the bottom of the board directly to the socket pins. Ignore the inductor in the picture, it helps but isn't as crucial.
From experience the Sanguino can be prone to stray fields and adding this capacitor is one method of improving this.
The attached documentation is provided from AVR040: EMC Design Considerations
[www.atmel.com]
Re: Lack of bypass/decoupling Capacitors on Sanguino
December 06, 2012 07:25AM
Generation 7 Electronics has such a capacitor already as well as a noise canceling coil/cap for analog (thermistor) measurements.
December 06, 2012 11:48AM
It already has one, C14 under the chip.
December 06, 2012 11:53AM
Sorry, thought you meant Sanguinololu.
Edited 1 time(s). Last edit at 12/06/2012 11:54AM by nophead.
