I've assembled my Prusa i3 and have been unable to melt the abs for printing due the sanguino incorrectly reading the hotend temperature. I'm currently using cura 13.11.2 and sprinter on my sanguinololu 1.3a with 104GT-2 Semitec thermistors. The hotbed and hotend begin to heat up when I start the print, however the heating curve read by cura does not follow the actual temperature of the hotend as read by a temp gun. cura shows the temperature heat up and level out at the designated temperature and it seems to be running correctly, however the actual temperature is significantly less and i have been unable to break 115 C. here is a copy of my config.h file [
pastebin.com]. I'm not sure whats going wrong or where I messed up so if anyone has any ideas, thanks for the help
