Sanguinololu & Kliment's SD RAMPS solder?
Posted by fteo88
July 25, 2011 01:33AM
I bought Kliment's SD RAMPS from Ultimachine.
How do I solder the connectors? Does it even fit the Sanguinololu 1.2?
Hello,
I have a version specifically for Sanguinololu. It IS possible to connect the sdramps to SL, but it's not as easy. The pinout of the sdramps is at [koti.kapsi.fi] (seen from the side with the LED and card socket, use QCad or inkscape to open). The SS pin connects to A0 on the sanguinololu, the rest of the pins are on the SPI connector next to the reset button. Poke me on the #reprap IRC if you have any questions.
Kliment
Re: Sanguinololu & Kliment's SD RAMPS solder?
July 25, 2011 04:47PM
Thanks, I am mapping SS to A0. What does ALT_SS map to?
Plus, I am assuming NC are not needed. The rest I can figure how to wire them.
July 25, 2011 04:50PM
I am also assuming the shining SD card reader is the top side or faces up on the sdramps.dxf. I hope this is correct?
Yes, the shiny side is up. You can leave alt_ss unconnected.
Kliment
July 26, 2011 06:45PM
I took a magnifying glass to the card and spotted the small LED next to the SD reader.
Once I map the wires, pronterface should recognize it I hope. I'll keep you posted.
Thanks
Cheers
August 02, 2011 12:12PM
OK had everything wired correctly.
When i SD upload using Pronterface (2 days ago) I get: open failed, File:pla_coup.g.ok.
What do I need to do.
