Robots and 3D Printing :-)
January 13, 2017 12:51AM
Hey All!
Not sure if this is the right place to put this but I'll put it here anyway...
After finally getting my 3D printer up and running, I am left with a number of the RepRap Full Graphic Display units. While I am build my robot (or 3) I would love to use this display in them. Does anyone know where I can get any information on how to use the display (memory card, controller, beeper) In a project other than a RepRap printer?
Any help would be appreciated!
Thanks in advance!
Don W.
Re: Robots and 3D Printing :-)
January 13, 2017 02:14AM
I moved that thread in a more fitting subforum, you'll get more answers here.
Is this the display you are talking about ? [reprap.org]
Note the difference between RepRap (we, the community, this reprap.org site) and RepRapDiscount (maker and seller of parts for reprap machines).
Can you tell us a little more about your skillset ? Ideally if you can program a bit you could read the code that use those displays in the existing firmwares code, and adapt it to your needs.
January 13, 2017 02:56AM
Try here [forum.arduino.cc]. The LCD used in those displays are standard 12864 displays with ST7920 controller chips. The usual software library for driving them is u8glib.
January 13, 2017 12:27PM
Thanks Guys!
I've been in computer for about 30 years now... been out a while (was my job now retired) now getting back into it. dc42 has given me the info I need though...
Thanks again for your help!
Don
