Melzi Drive Capacity
Posted by drcymru
July 03, 2013 08:18AM
Hi All
I have a Melzi Board on my Mendal and want to swap the extruder drive stepper motor for a linear actuator stepper motor to drive a syringe.
I have found a bipolar motor which is rated at 2.33v and 1.5A (1.5A per phase....).
My question is, will my Melzi board deliver enough current to drive this new motor?
I'm not sure whether the board will be overloaded or not.
Are both phases of a bipolar stepper motor ever active at the same time (which would mean 3A being drawn... which is probably too much for the Melzi).
Any help gratefull recieved.
Thanks
Re: Melzi Drive Capacity
July 27, 2013 01:10PM
They are limited to 2 amps per phase so that should be fine. The limit is per phase so you don't have to worry about both on at the same time. At 1.5 amps you will likely need a heat sink and fan on the drivers.
