I am making 3d printer. It will be my first. This will get me into the world of 3d printing.
These are the files that i need printed
www.thingiverse.com]
List of what i need is as follows. the quantity of each part is in parenthesis
(2)3d print corner short repaired mirrored
(1) 3d y slide 2 repaired
(2) 3d print corner short repaired
(1) 3d y slide repaired
(1) bottom x slide
(1) top x slide
(4) belt holder
(2) vertical screw 2
(8) vertical rod holder
(2) vertical screw 1
Parts need to be printed out of abs with a 4mm shell thickness and a minimum 35% infill. Please give me a quote for the parts. Thank you for any help you are able to provide.
BTW: I am out of Massachusetts USA
