I use $65 to make a mini laser cutter December 08, 2014 01:53PM |
Re: I use $65 to make a mini laser cutter December 08, 2014 03:13PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: I use $65 to make a mini laser cutter December 08, 2014 04:22PM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: I use $65 to make a mini laser cutter December 09, 2014 01:49AM |
Re: I use $65 to make a mini laser cutter December 09, 2014 01:50AM |
I also want to do a co2 laser cutter , but it was too dangerous. So I want to do a small machine first, if you want to make the co2 laser cutter,you need to do enough protection work like lasering protective eyeglass. I think you will be successful.Don't forget to share your successQuote
Ohmarinus
So cute and small! I'm also looking into building my own lasercutter. After seeing some of the homemade designs lately, I think I can do this too!
Only thing is, I want to create one that actually can cut wood. The whole problem is that I probably need a CO2 laser to do that, which doesn't come in small packages. They usually use expensive mirrors and lenses to reflect the laser beam through the system onto the cutting material.
Re: I use $65 to make a mini laser cutter December 09, 2014 02:14AM |
Thank you for sharing your experience,I would to choose 445nm laser tube.but there was a problem focus the lens.I give the machine a weak light circuit.Quote
VDX
... I'm cutting light wood or plywood (white poplar, birch or balsa) with 445nm-diodes with (real) powers of 2Watts and 3.5Watts/4Watts with several passes until 5mm thickness.
But have some high quality birch plywood with watertight glue too, where it cuts only the first sheet, then the glue blocks the laser totally!
CO2 is better for wood in counts of sheer power (+40Watts compared to 4Watts), but the 445nm-diodes have a finer spot, so are more accurate for engraving and much easier in handling and maintenance ...
Re: I use $65 to make a mini laser cutter December 12, 2014 03:34AM |
Re: I use $65 to make a mini laser cutter December 12, 2014 11:39AM |
Re: I use $65 to make a mini laser cutter December 12, 2014 05:21PM |
Re: I use $65 to make a mini laser cutter December 13, 2014 06:42AM |
Re: I use $65 to make a mini laser cutter December 13, 2014 07:14AM |
Re: I use $65 to make a mini laser cutter December 13, 2014 07:50AM |
Re: I use $65 to make a mini laser cutter December 13, 2014 09:35AM |
Re: I use $65 to make a mini laser cutter December 13, 2014 12:18PM |
Components to build a 700-1000mW focusing red laser module (12V): Parts List:
Oclaro 700mW+ diode, new stock packed in antistatic bag with datasheet. Rated at 700mW continuous.
Module housing; Standard 5.6mm laser diodes clamp into this housing. Fan cooling for high power operation. Takes standard 9 x 0.5mm Lens (not included), adjustable focus. Ideal for Laser cutter/ engraver projects.
Driver; A 12V driver for high power, continuous use applications. TTL modulation up to 30KHz. Fan support.
Lens; 3 element glass lens with 630-660nm (centre wavelength) anti-reflective coating for 9.0 x 0.5mm threaded laser diode housings.
Re: I use $65 to make a mini laser cutter December 13, 2014 04:46PM |
Re: I use $65 to make a mini laser cutter December 14, 2014 06:14AM |
Re: I use $65 to make a mini laser cutter December 14, 2014 03:25PM |
Re: I use $65 to make a mini laser cutter December 15, 2014 09:10AM |
Re: I use $65 to make a mini laser cutter December 15, 2014 10:36AM |
Re: I use $65 to make a mini laser cutter December 15, 2014 07:22PM |
Re: I use $65 to make a mini laser cutter December 18, 2014 11:18AM |
Re: I use $65 to make a mini laser cutter December 26, 2014 04:26AM |
Re: I use $65 to make a mini laser cutter December 26, 2014 01:06PM |
Yeah,i was sales the preview machine on taobao.Good effects as you can see.but i still have a lot of things to improve.r u from china? if u want this machine.i will start a campaign on indiegogo. You can follow my blog,i will update the msg about this mahchine,at last i will open the drawing.its a open source project.Quote
ekaggrat
are you on taobao?i think i saw this there but lost the link
