That's the kind of object where it is probably worth designing support into the stl, then printing without support enabled in the slicer. You can probably get away with a couple of thin walls, and let the rest be bridged. For example, I designed in support on this: [
www.thingiverse.com] which significantly reduced the amount of support material, and increased the quality of support compared to slic3rs default.
