DiffBot - Differential Screw-Driven XY Gantry September 22, 2019 09:16PM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 03:55AM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 04:17AM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 05:49AM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 07:01AM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 07:09AM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 10:06AM |
the_digital_dentist
Interesting, but I suspect the hardware to make it work is going to be pretty expensive. My experience with using cheap gears to make a belt lifted Z axis tells me that any flaws in the gears are going to show up as repeating defects in the prints each time each of the gears makes one rev. You're going to need very high quality (read expensive) gears to make it work well. What happens to print quality as the gears wear?
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 10:12AM |
MKSA
A CoreXY is also a "differential" based system.
I fail to see the advantages, as for issues, you noticed a few already.
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 12:07PM |
Apsu
MKSA
There's quite a few potential advantages if executed well. I mention a bunch at the bottom of the github document, but to recap:
No long complex belt paths means less issues with tensioning/alignment/pulleys/tiny bearings/hysteresis/stretch/temperature.
Easier material choices to fully enclose the gantry in a high-temp enclosure for the most challenging materials, like PEEK.
Simple and relatively cheap assembly with low part count.
Easier to change mechanical ratios without dealing with pulley sizes increasing.
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 12:16PM |
MKSA
What kind of test did you carry to back your claims ?
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 02:37PM |
Apsu
MKSA
I'm not sure you're following what I'm presenting here. The items I listed as potential benefits over a belted system are observations of facts based on assuming a well-executed build in terms of materials and mechanical construction. There's no testing required to note the advantage of a screw over a belt in the aspects I mentioned. Or that the part count is lower than a CoreXY, or that you don't need to worry about the small bearings used in 5mm bore pulleys. And so on.
Doesn't mean it's an automatic win, there's a lot of engineering going on here and ways to fail. Plus there's factual disadvantages that need to be overcome, like requiring a higher motor RPM for lower screw leads to achieve equivalent gantry speeds to belts, something that small frame stepper motors struggle with.
If there's something about this list of obvious observations you think needs to be tested, please elaborate.
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 02:41PM |
MKSA
Apsu
MKSA
Don't worry, I followed, found this mechanism "obvious" and didn't need to read you "explanation" but I consider irrelevant your list of obvious advantages from obvious observations
OK on a computer simulation not in real life.
So do a prototype THEN do a list of REAL pro and cons.
Please avoid listing the build shortcomings of other machines for ex. the small bearings used in CoreXY.
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 03:17PM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 03:26PM |
Apsu
Nah. I tried to engage you in a discussion but since it's such an obvious mechanism you didn't read what I wrote, I will return the favor. Best of luck to you
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 03:30PM |
cozmicray
Perhaps a sprial bevel gear
[www.thingiverse.com]
they are very smooth and used in Hi torque applications (differentials)
?What is the best (smoothest) right angle gear configuration?
Have to also consider the locking of the gear?
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 05:23PM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 06:00PM |
MKSA
So no need for "conversation", just build the prototypes and prove your points.
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 06:02PM |
leadinglights
MKSA
Hmmm, and I always thought that a forum was a place you come to discuss ideas, to have a conversation.
I never realised that it is just a place to present a glorious and finished design, unsullied by the input from anybody else.
Mike
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 06:03PM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 23, 2019 06:52PM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 24, 2019 12:16AM |
leadinglights
MKSA
Mike
Re: DiffBot - Differential Screw-Driven XY Gantry September 24, 2019 03:15PM |
leadinglights
MKSA
Mike
Re: DiffBot - Differential Screw-Driven XY Gantry September 25, 2019 01:34AM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 25, 2019 03:52AM |
Trakyan
Well someone came out from under the bridge.
Anyways, the "parasitic" effect I was meaning mostly is if friction between the nut and screw causing the nut to spin with the screw (thus not moving axially as it should) rather than stay stationary when you want it, or vice versa friction in the bevel gears stopping the nut from rotating freely with the lead screw (and thus causing it to move axially when not intended). These would possibly cause racking, which would make these sources of friction worse and so on. I'm planning on finally getting to build a CNC either late this year or early next year and I'd be happy to help with the prototyping and R'n'D.
As for backlash, I just remembered this type of anti backlash nut I saw a while ago, might be useful.
[eu.makerdise.com]
The spring force is applied radially via a collet type system. They means that axial forces in the direction of the screw (say cutting forces on a router/mill) can't compress the spring and reintroduce the backlash.
Also a suggestion for the bevel gears if backlash is an issue, you could use two angle drums coupled by a cable. These sorts of mechanisms are very low backlash and very cheap/easy to make compared to bevel and spiral bevel gears.
Also I think there's a way to simplify the mechanics. If you used two different Y axis screws, one left handed one right handed. Then added a worm wheel to either end of the X axis screw which mates to the Y axis leadscrews. I think this would give the same mechanical response with fewer parts. I could be wrong, haven't had too much time to think this through. The two different Y screws might not be necessary now that I think about it, maybe they can be the same handed-ness.
Re: DiffBot - Differential Screw-Driven XY Gantry September 25, 2019 06:54PM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 25, 2019 07:24PM |
Trakyan
I get you on not wanting flexibility from cables, but what I'm talking about the cables are very short, they are only enough to wrap around the two drums that are almost touching in a figure 8 type arrangement, they serve to take out backlash/slop more than transmit force. It was just a suggestion for some ghetto low backlash gears.
Why would the worm need to back drive the pinion? All the motive force comes from the Y screws being driven by the motor, the worm wheel shouldn't ever be driving the screws. You're right that you wont get a 1:1 gear ratio. Perhaps using a higher lead on the X axis screw to make up for the gear reduction from the worm? Or maybe just say its a feature not a bug
Upon some closer thinking, what would be needed for the worm-wormwheel version I think is not different handed-ness of screws, but have one leadscrew connected at the top of a wormwheel, the second at the bottom. That way when both Y screws are trying to advance forward or backward, they try to turn the X screw in opposite directions so it doesn't rotate, and instead the worm wheels advance along the leadscrew giving Y axis movement. Similarly, when the Y screws turn in different directions they will both turn the worm wheels in the same direction, so the X screw spins giving X axis movement. This sort of combines the lead-nut and bevel gears into one using the worm wheel which shortens the component list and reduces sources of backlash. The asymmetry of this design (one leadscrew contacting on top, one on bottom) bugs me though, your version looks more pleasing to the eye.
A side effect is that this setup could be cantilevered (I personally wouldn't want to, but ya'know), Two parallel lead screws (your driven lead screws) with a worm wheel sandwiched between and another leadscrew attached to that worm wheel acts as your other axis. I'm sort of rambling here.
But wow, your setup is very easy to back drive, maybe I'm overthinking the parasitic friction.
Re: DiffBot - Differential Screw-Driven XY Gantry September 27, 2019 10:49PM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 28, 2019 08:00AM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 28, 2019 11:10AM |
Re: DiffBot - Differential Screw-Driven XY Gantry September 29, 2019 08:02AM |
