RepRap Mendel 3D printer full kit (made in UK).
Print your three-dimensional creations in high definition using ABS, organic PLA or super strong and flexible Nylon thermal plastics. Design works of art, technical components or complete products ready for the end user quickly and easily with you own 3D printer. Create complex geometric designs that only a 3D printer can handle or just replace the do-dad that's broken off the dishwasher or washing machine. Your only limited by your own imagination.
Technical Specifications:
- Build volume: 210x190x140mm
- Overall size: 500x460x410mm
- Printing materials: ABS, PLA, Nylon 1.75mm diameter thermoplastic.
- Build surface: PCB-heated bed to reduce complexity of assembly and to ensure parts do not warp.
- Computer interface: USB
- X-carriage: Three Z-adjustable deposition head mounts; one head supplied.
- Accuracy: 0.1mm
- Resolution: 0.0125mm
- Building speed: 1,800 mm/min
- Moving speed: 12,000 mm/min
- Deposition rate: 33 cm3 / hr
- Motion: Linear ball bearings on X and Y axes, Igus low friction bushings on Z axis.
- Pre-soldered electronics with built-in microSD card slot for standalone printing.
- Enhancements to the printed parts to improve the ease of assembly of the X and Y axes
What's Included:
- All hardware (threaded and smooth rods, screws, nuts, washers, belts, bearings etc)
- Pre-soldered and programmed electronics
- MicroSD card + adapter
- Heated PCB build surface (requires eight soldered joints)
- Motors
- Nozzle assembly and extruder drive mechanism
- 100m of 1.75mm diameter PLA filament (approx 300g) for printing with
- Power supply
- All the 3D-printed Mendel parts
More information here!
