Any recommendations on using a RAMBo on the Wilson TS? December 27, 2014 07:12AM |
Re: Any recommendations on using a RAMBo on the Wilson TS? February 05, 2015 11:11PM |
Re: Any recommendations on using a RAMBo on the Wilson TS? May 07, 2015 07:02PM |
Re: Any recommendations on using a RAMBo on the Wilson TS? May 08, 2015 01:31AM |
dantman
...I've heard of issues with the polyfuses on the RAMPS boards and am considering instead using a RAMBo from RepRapElectric...
Re: Any recommendations on using a RAMBo on the Wilson TS? May 09, 2015 12:10AM |
Yeah. I'll end up doing this.Quote
milkypostman
you can hook up the rambo and use it to print your own mount. i mean, the rambo doesn't *need* to be mounted. just put a fan on it.
Kit, what kit? When I posted this the Wilson TS was still marked as under development and I couldn't find any kits. And going a google search again, I still don't see any Wilson TS kits.Quote
AndrewBCN
The Wilson TS kit is shipped with a RAMPS and I suggest you test assembling and using it as is, and only then, if you are not satisfied with the performance of the Arduino + RAMPS stack (I doubt it), print your own mount for whatever other electronics you want to install instead.
Ok. When I asked all the Wilson topics I found were in this forum. And the other forum's description was fairly vague about how far "and variants" went.Quote
AndrewBCN
Edit: please note that the correct forum to post questions about the RAMPS is... the RAMPS forum below. And the correct forum to post questions about the Wilson TS is in the "Prusa i3 and variants" forum.
Re: Any recommendations on using a RAMBo on the Wilson TS? May 09, 2015 10:09AM |
Re: Any recommendations on using a RAMBo on the Wilson TS? May 09, 2015 03:39PM |
milkypostman
The creator of the Wilson sells kits. I don't know how but I found out info about it somewhere. You can search eBay for his sales and contact him directly about it. Originally I was going to source the parts myself then learned about the kit.
The stepper motors I found say 52N.cm so I'm probably fine.Quote
milkypostman
Guess it's too late for you now so sorry about that. The major thing he does in his kit is provide high torque motors from automation technologies and provide an e3d v6 lite hotend.
