Delta movement conventions - ANSWERED
Posted by aussiephil
May 16, 2016 11:32PM
To all the Delta gurus....
Running a little confused on expected X-Y movement, so as per the attached image
If tower C = Z
A = ??
B = ??
If X movement is 1-2 and Y movement is 3-4
Then which is the minus and plus directions?
Cheers
Phil
IGNORE the attachment in this post, Diagram attached by PRZ shows the movement conventions.
Edited 1 time(s). Last edit at 05/18/2016 08:31PM by aussiephil.
open | download - CaptureD.JPG (30.7 KB)
Re: Delta movement conventions
May 17, 2016 02:32AM
A=Y
B=X
Both axis are minus to the Front Left and positive at Rear right.
HTH
Edit to correct Brain Fade moment
Edited 1 time(s). Last edit at 05/18/2016 02:34AM by dougal1957.
May 17, 2016 06:58AM
Doug:
Ok, swapped my left right towers as i had them wired the other way, now have X moving positive to the right and negative to the left with the Z tower at the rear.
All homing works.
Now the Y directions is different to what you posted above with positive going to the rear. This is inline with other posts I could find this evening including one by yourself
Now just want to confirm Y though i can't see it could be any other way if all the other movement is correct.
May 17, 2016 08:41AM
I'll double check on mine and report back in about 15 mins
May 17, 2016 08:44AM
You are quite right that's what you get trying to do things from an ageing memory
So to get it right both axis are Positive at Rear Right and negative at front Left.
I'm getting to old and demented to do things by memory? Note to self Double check what you post before hitting the Send button Doh?
May 17, 2016 08:02PM
dougal1957
smiling smiley no dramas I got it sorted but it could be worth editing your first reply to avoid confusion down the track to others.
Cheers and thanks for checking
Phil
May 17, 2016 09:45PM
dougal1957
In other words both axis are minus to the Rear Left and positive at front right.
HTH
The correct convention is both axes are minus in the FRONT left and positive in the REAR Right
...ohh sorry see this has already been corrected
RepRapPro Mendel 3 Tricolour
RepRapPro Fisher
-Carbon Arms
-Easy adjust Carriage+effector
-axis stiffness mods
HE3D -600 delta
-Duet 0.8.5
-PanelDue
-DC42 Height probe
-RobotDigg metal components
Simplyfy3D
RS Design Spark CAD
PRZ
May 18, 2016 06:57PM
I have added a schematic on the wiki Delta geometry page. View from top.
Delta_geometry#Delta_columns_and_axis_names [reprap.org]
AussiePhil, I found that in Repetier the A and B column names are reverted compared to your drawing, see [www.repetier.com] , where did you get it ?
Pierre
- Safety [reprap.org]
- Embedded help system for Duet and RepRap Firmware [forums.reprap.org]
- Enclosed delta printers Lily [rouzeau.net] and Lily Big [rouzeau.net]
- OpenScad delta printer simulator [github.com]
- 3D printing on my site [www.rouzeau.net]
May 18, 2016 08:29PM
Hi Pierre
Many thanks for adding that to the Wiki, I'm good at Google searching for info but never found that diagram.
I'm trying very hard to learn by research and only ask when I just can't find it or understand.
The diagram I posted I just drew and just nominally put letters to the to front columns.
Cheers
Phil
