Delta movement conventions - ANSWERED May 16, 2016 11:32PM |
Re: Delta movement conventions May 17, 2016 02:32AM |
Re: Delta movement conventions May 17, 2016 06:58AM |
Re: Delta movement conventions May 17, 2016 08:41AM |
Re: Delta movement conventions May 17, 2016 08:44AM |
Re: Delta movement conventions May 17, 2016 08:02PM |
dougal1957
You are quite right that's what you get trying to do things from an ageing memory
So to get it right both axis are Positive at Rear Right and negative at front Left.
I'm getting to old and demented to do things by memory? Note to self Double check what you post before hitting the Send button Doh?
Re: Delta movement conventions May 17, 2016 09:45PM |
dougal1957
In other words both axis are minus to the Rear Left and positive at front right.
HTH
Re: Delta movement conventions May 18, 2016 06:57PM |
Re: Delta movement conventions May 18, 2016 08:29PM |
