Want to build a kossel XL. November 09, 2017 09:18PM |
Re: Want to build a kossel XL. November 10, 2017 02:07AM |
Re: Want to build a kossel XL. November 10, 2017 03:42AM |
Re: Want to build a kossel XL. November 10, 2017 11:27AM |
Re: Want to build a kossel XL. November 11, 2017 04:07PM |
Re: Want to build a kossel XL. November 12, 2017 04:33AM |
o_lampe
I've built my Kossel XL upside-down with the small Robotdigg corners screwed to a solid MDF plate. That made a huge difference, but I'd chosen the wrong carbon rods. 6mm rods x 330mm long are not sufficient for fast prints with a heavy Diamond hotend.
So it only collected dust until I decided to give the smart effector with Haydn Huntleys magball rods a chance. To my surprise the rods are also 6mm dia.
I haven't got it running yet, but with a single extruder it'll do.
The Tevo monster approach is a bit weird. The C-beams stability are out off the question, but when the sheet metal plates aren't exactly flat, you're busted...
( I had a not_so flat round aluminum bed in my Kossel XL and despite RRF autocalibration it was a nightmare to print the 1st. layer.)
BTW: I've built a CoreXY too, but decided from the start to use linear rails and three ballscrews for the bed. No more wobbling or binding
[attachment 99507 ballscrews_x3.jpg]
Re: Want to build a kossel XL. November 12, 2017 05:09AM |
DjDemonD
I like the Tevo LM approach its a very simple frame and should be very sturdy. Get precision cut end plates made by laser cutting/waterjet which are thick enough and flat enough.
Then use linear rails, 0.9 degree steppers, Duet controller, Piezo probe/smart effector, magnetic rods, remote direct extruder.
Should be a pretty awesome delta. I've got one - and I love it. Mine is a Kossel style metal frame, as I made it before Tevo LM style frame was around but its stiff, calibrates to ludicrously low deviation 0.005mm or so and prints great.
Re: Want to build a kossel XL. November 12, 2017 05:18AM |
Re: Want to build a kossel XL. November 12, 2017 05:19AM |
dc42
I built a large Kossel two years ago, upgraded it several times, and finally rebuilt it earlier this year. It worked well from the start and got better with each upgrade. I described the journey at [miscsolutions.wordpress.com] and subsequent blog upgrades, and the rebuilt version at [miscsolutions.wordpress.com].
Some people prefer to put the electronics and motors at the top, and just the PSU and bed heater SSR under the bed.
Re: Want to build a kossel XL. November 12, 2017 05:21AM |
Re: Want to build a kossel XL. November 12, 2017 05:32AM |
Vigilant
dc42
Wouldn't steppers at the top make it top heavy ? and vibrate more.
