Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 15, 2017 06:08AM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 15, 2017 09:59AM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 15, 2017 02:16PM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 15, 2017 02:23PM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 16, 2017 05:30AM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 16, 2017 05:39AM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 16, 2017 07:33AM |
DjDemonD
I've brought up the topic of belts, and improving quality/reliability of belts many times, but generally, most people are fairly dismissive of the idea, as if belts are just belts and cannot be improved, they are cheap and cheerful. This is true but many/most do not replace their belts routinely. The general opinion is that we are not using the belts anywhere near their capabilities, but then if this were the case, why do they stretch, partially fail and fail when used in 3d printers?
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 16, 2017 07:37AM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 16, 2017 08:26AM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 16, 2017 11:55AM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 16, 2017 02:47PM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 16, 2017 03:00PM |
Re: Lean/Slant on Flsun Kossel - SOLVED (It was the belts!) November 16, 2017 04:21PM |
