Layer Shifting Phenomenon May 08, 2019 08:40AM |
Re: Layer Shifting Phenomenon May 08, 2019 09:26PM |
Re: Layer Shifting Phenomenon May 10, 2019 07:05AM |
Re: Layer Shifting Phenomenon May 10, 2019 07:38AM |
Re: Layer Shifting Phenomenon May 10, 2019 10:00AM |
Re: Layer Shifting Phenomenon May 10, 2019 10:42AM |
Re: Layer Shifting Phenomenon May 10, 2019 12:19PM |
Re: Layer Shifting Phenomenon May 10, 2019 03:57PM |
Re: Layer Shifting Phenomenon May 11, 2019 12:51AM |
Re: Layer Shifting Phenomenon May 11, 2019 03:14AM |
MobiusOne
The only issue I have now is that when I open up my G-CODE file from the Duet Web Server, I get repeating directories... and A LOT of them. I only have six top-level directories for G-CODE on my SD card, but those six are repeated DOZENS of times. Sometimes it will clear up after a quick interface refresh but sometimes they stay there. I'll rule it a true new problem after I've done the WiFi channel swap over though.
Re: Layer Shifting Phenomenon May 16, 2019 10:14PM |
Re: Layer Shifting Phenomenon May 17, 2019 09:05AM |
Re: Layer Shifting Phenomenon May 17, 2019 05:50PM |
Re: Layer Shifting Phenomenon May 18, 2019 12:09PM |
Re: Layer Shifting Phenomenon May 18, 2019 03:09PM |
Re: Layer Shifting Phenomenon May 18, 2019 04:24PM |
Re: Layer Shifting Phenomenon May 18, 2019 04:45PM |
Re: Layer Shifting Phenomenon May 18, 2019 11:28PM |
hercek
If your parts are narrow like this:
Then you may have just a simple skipped step on one or more towers. The XY shift is so small that you may not notice that there is also Z shift.Try to break those parts. Are they breaking much more easily at the location of the the shift? If yes then you probably have also Z shift which you re not noticing i.e. it can be a skipped step.
Re: Layer Shifting Phenomenon May 19, 2019 12:28AM |
Re: Layer Shifting Phenomenon May 19, 2019 01:15PM |
Re: Layer Shifting Phenomenon May 19, 2019 05:46PM |
Re: Layer Shifting Phenomenon May 20, 2019 07:23AM |
