Re: RepRap 3DR Delta printer Released February 28, 2014 09:02AM |
Re: RepRap 3DR Delta printer Released February 28, 2014 09:55AM |
Re: RepRap 3DR Delta printer Released February 28, 2014 12:24PM |
Re: RepRap 3DR Delta printer Released February 28, 2014 03:26PM |
Re: RepRap 3DR Delta printer Released March 05, 2014 03:58AM |
Re: RepRap 3DR Delta printer Released March 05, 2014 12:19PM |
Admin Registered: 15 years ago Posts: 1,470 |
ekaggrat
how do you get rid of this seam line ?
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: RepRap 3DR Delta printer Released March 06, 2014 10:23AM |
Re: RepRap 3DR Delta printer Released March 06, 2014 08:45PM |
landsharkxx
How much does it cost to build this?
Re: RepRap 3DR Delta printer Released March 07, 2014 11:10AM |
Re: RepRap 3DR Delta printer Released March 07, 2014 12:35PM |
TheCrey
is it possible to just make the printer higher ? I mean i have some 100cm rods here, could i just scale it higher without any issues ?
RichRap
"Is 3DR scale-able?" Yes, easy to go taller, just needs some thought about rod length. To go wider you will need to consider rod sizes. I always intended to be able to insert another printed part (spacer) and a new bigger middle triangle to get an overall bigger build area with the same parts. I actually wondered about keeping the size smaller to start with and doing extensions that could be printed out in order for it to be able to self reproduce, but that was getting messy.
And to the person who asked me if it's possible to make a Delta printer 3 Meters tall - YES!, Oh yes!, you can and if you build one (or want me to make you one) - please let me know
Re: RepRap 3DR Delta printer Released March 07, 2014 01:17PM |
Re: RepRap 3DR Delta printer Released March 11, 2014 11:09PM |
HaDe
How's your 3DR doing? Have you found points and/or solutions for improvements? I still would like to increase frame stiffness, but have no idea how to get real improvements without a major redesign. The main flex appears to be in the top & bottom printed parts.
Re: RepRap 3DR Delta printer Released March 11, 2014 11:18PM |
Re: RepRap 3DR Delta printer Released March 12, 2014 04:37AM |
Re: RepRap 3DR Delta printer Released March 15, 2014 09:33AM |
Re: RepRap 3DR Delta printer Released March 15, 2014 09:57AM |
Re: RepRap 3DR Delta printer Released March 15, 2014 12:08PM |
Re: RepRap 3DR Delta printer Released March 15, 2014 04:38PM |
Re: RepRap 3DR Delta printer Released March 15, 2014 09:39PM |
Re: RepRap 3DR Delta printer Released March 16, 2014 01:40AM |
Re: RepRap 3DR Delta printer Released March 16, 2014 07:57PM |
Re: RepRap 3DR Delta printer Released March 16, 2014 10:37PM |
Re: RepRap 3DR Delta printer Released March 17, 2014 03:29AM |
Re: RepRap 3DR Delta printer Released March 17, 2014 04:00AM |
Re: RepRap 3DR Delta printer Released March 17, 2014 01:06PM |
Re: RepRap 3DR Delta printer Released March 19, 2014 02:44AM |
Re: RepRap 3DR Delta printer Released March 19, 2014 03:23AM |
[www.conrad.at]Quote
Self-adhesive sensor surface.
Romank
It worked also with only one FSR.
Re: RepRap 3DR Delta printer Released March 21, 2014 01:50PM |
Re: RepRap 3DR Delta printer Released March 22, 2014 06:59PM |
Re: RepRap 3DR Delta printer Released March 24, 2014 04:58AM |
