A2
Re: Worm Drive Grounded Delta Printer
December 09, 2013 10:20AM
Tks for the update!
If time permits, I would really like to see a video of the movement, that you would like to correct with the parallelogram linkage. smiling smiley
December 09, 2013 06:03PM
@Jon: I am not sure what is meant by a parallelogram linkage. Are you talking about something like THOR Simpson? It would only work if you do that to two arms. However, I would advise you to figure out what the weak link is and beef it up. (Mathematically, your position should be constrained so it is just a matter of sizing all the components to get acceptable rigidity.)
I know this would be annoying to do but the the worm needs to be registered with a pair of bearings and some thread clamps.
I would also consider splitting the shoulder gear and adding a torsion print as a backlash removal attempt.
Note: My apologies if you have already done some of these things.
Good luck!
Edited 1 time(s). Last edit at 12/09/2013 06:03PM by nicholas.seward.
December 10, 2013 12:03PM
nicholas.seward
Good luck!
I agree, finding the weak link is the most prudent course. I have been working on a more beefier effector, the pivot arms are fairly small and could be the source of the flexing. I have been getting some grief printing the thicker parts in ABS. If that didn't solve the issue, then I was considering replacing one arm with a parallelogram like with the THOR simpson.
Here is a vid
Youtube
Edited 1 time(s). Last edit at 12/10/2013 12:15PM by Solidus Labs.
December 10, 2013 12:15PM
@Solidus Labs: I think I know your main problem.
Test: Move the extruder to about 100mm above you surface. Press down and see if it is more rigid.
If it is more rigid, you just need to move your shoulder joints down so you stay far away from the planar singularity. (Your extruder is much closer to the joints than mine is.) That and beefing up your long arms should get you there. The shoulder looked good to me. Remember you don't need to add much plastic. You just need to add dimensionality to the arms. The rigidity is a function of b*h^3. If you just turn your arm on its side you will get 4 times the rigidity by my estimates. My theory is to go big with low infill.
A2
December 10, 2013 01:17PM
Love the sound track grinning smiley
Tks for taking the time to post the video, love the eye candy!
A few ideas to consider.
Shoulder joint support structure:
I don't see a bottom triangular base tying the three shoulder joints together, ie. boxing in the structure.
Without a bottom base boxing in the shoulder joints, I can envision that the top plate is flexing (oil canning) downward, and the shoulder joints splaying outward.
Adding a bearing at the top and bottom of the rotational shoulder joint (Z axis), separated by as much space as is available will help with rigidity.
December 10, 2013 01:38PM
nicholas.seward
*face palm* Ahh you’re right. Without even testing I can tell you it is more rigid.
I move the horizontal pivot point up on the shoulder for more clearance but that also moves the horizontal singularity up.
Thanks for fresh pair of eyes.
A2
December 10, 2013 02:33PM
Awesome +1 smileys with beer
December 12, 2013 09:27AM
Printereing some new shoulders
youtube candy
January 04, 2014 08:47PM
How are things going? How do the new shoulders work out? Did they get rid of that singularity?
January 06, 2014 11:51AM
AbuMaia
Sorry there has not been an update for a while. I was really busy over the holidays. The new shoulders have improved the flexing on the singularity quite a bit. I am currently rebuilding the hot end to extend farther down and get further from the singularity. The prototype I built has very good position stability but has heat zone and jamming issues. Lowering the nozzle has cut into the z height so I need to reprint longer upper arms as well.
- Jon @ Solidus Labs
January 09, 2014 04:01PM
Yay! First “successful” print. There are still some flaws in the printing but I think I can fix that with some small tweaks in the calibration.
January 09, 2014 04:47PM
@Jon: As far as I know there have only been 4 individual Simpson style printers that have actually printed. (I hope this year that number goes to 100s) You are #4 with a unique design nonetheless!!!!!!!!
January 09, 2014 07:06PM
Excellent! Can't get much closer to the spirit of reprap than this! Almost everything is printed, only the motors, worm gear, electronics and hot end need be purchased. Well... a few bolts and bearings huh? But no belts, no long threaded rods, no metal cutting or shaping. I really hope you will release the files soon.
[www.linistepper.com] Open source stepper motor drivers.
A2
January 09, 2014 07:17PM
@Jon,
Looks fantastic! thumbs up
Got video candy? grinning smiley
End effector Hub assembly:
I just noticed your hot end design/assembly! thumbs up
It looks like you have a bespoke hollow threaded aluminum tube running down the center of your end effector hub.
Are you using the aluminum tube to sandwich the hub, and bearings tightly together so the assembly is ridged?
Are the 3 bearings touching each other, or is there plastic separating them?
The bearings look larger than 608's, what series are you using?
Redesign of the Hot end/end effector/hub:
To increase rigidity of the end effector I'm redesigning it to use a hollow threaded rod with bearings clamped in between.
Either an electric lamp fitting, vented SHCS, a vented stud, or your hollow threaded aluminum tube will be used.
A discussion about the end effector modification begins in the Lisa thread:
[forums.reprap.org]
Material suppliers:
Electric lamp fittings
[www.sizes.com]
1/4-27, Dia 6.35 mm (0.250"), 626 bearing 6x19 mm.
1/8-IP, Dia 10.29 mm, (0.405"), 6800 bearing 10x19 mm.
1/8-IP, Dia 10.29 mm, (0.405"), 6900 bearing 10x22 mm.
3/8-IP, Dia 17.15 mm, (0.675"), 6703 bearing 17x23 mm.
[www.bearingworks.com]
Lamp stuff
[www.profhdwr.com]
Lamp parts
[www.txlampparts.net]
3/8-ip nuts are 27 cents each at:
[www.iqlightbulbs.com]
M8x40mm, 7.41ea, Vented Socket Head Cap Screws
[www.mcmaster.com]
M8x50mm, $15.19ea, Vented Socket Head Cap Screws
[barnhillbolt.com]
5/16-18, $16.00ea, Hollow Threaded Studs
[www.mcmaster.com]
Hub offset:
I have a question about the end effector hub offset.
I want to design my arms to be inline with the end effector hub/pivot axis,
but I'm unsure if I'm violating the laws of physics.
In this image I can see that your end effector bore in the hub is offset relative to the arm.
Is this to prevent a singularity, or is it for some other reason?
Tks!
January 10, 2014 09:44AM
Excellent! And it has the stiffness to carry the extruder on top of the hub, that's amazing. Definitely deserves some videos. . .
A2
January 10, 2014 01:46PM
@Jon,
I'd like to verify that we have the newest version of the g-code preprocessor, is the math still the same?
What software language is this code written in?
tks!
double La_1;
double La_2;
double La_3;
double Da_1;
double Da_2;
double Da_3;
double Ra_1;
double Ra_2;
double Ra_3;
Ra_1=sqrt(sq(cartesian[X_AXIS]-V1_X)+ sq(cartesian[Y_AXIS]-V1_Y));
Ra_2=sqrt(sq(cartesian[X_AXIS]-V2_X)+ sq(cartesian[Y_AXIS]-V2_Y));
Ra_3=sqrt(sq(cartesian[X_AXIS]-V3_X)+ sq(cartesian[Y_AXIS]-V3_Y));
La_1=sq(Ra_1-Nx+Sx)+sq(cartesian[Z_AXIS]-Sv+Nv1);
La_2=sq(Ra_2-Nx+Sx)+sq(cartesian[Z_AXIS]-Sv+Nv2);
La_3=sq(Ra_3-Nx+Sx)+sq(cartesian[Z_AXIS]-Sv+Nv3);
Da_1=((sqL1L2-La_1)/theta_CEND);
Da_2=((sqL1L2-La_2)/theta_CEND);
Da_3=((sqL1L2-La_3)/theta_CEND);
if (Da_1 <-1 || Da_1 > 1)
    Da_1=floor(Da_1);
    SERIAL_ECHOPGM("Arm Limit X\n");
if (Da_2 <-1 || Da_2 > 1)
    Da_2=floor(Da_2);
    SERIAL_ECHOPGM("Arm Limit Y\n");
if (Da_3 <-1 || Da_3 > 1)
    Da_3=floor(Da_3);
    SERIAL_ECHOPGM("Arm Limit Z\n");
delta[X_AXIS]= acos(Da_1)*rad2ang;
delta[Y_AXIS]= acos(Da_2)*rad2ang;
delta[Z_AXIS]= acos(Da_3)*rad2ang;
January 11, 2014 01:09PM
Here is your youtube candy:
[www.youtube.com]
smiling bouncing smiley
January 11, 2014 01:21PM
re:End effector Hub assembly:
Yes the aluminum tube is threaded and screws the effector arms together.
There is plastic separating them. In the second picture you can see the hubs recess into each other.
They are 6804.
re:Hub offset:
The dogleg forearms have an off center shift, this is just shifting them back.
re:Hub offset
The formulas are still the same, I might have changed/added a few variables. The language is Arduino, which is more or less c++.
A2
January 11, 2014 01:36PM
Tks!
I love the looks of your GDR, the extruder sitting on top makes it look very cool.
January 12, 2014 12:38PM
.2 layer and .4 layer sample print
January 18, 2014 04:01PM
Small update:
I printed new longer forearms which will give more printable Z area. After a bit of re-calibration, here are some photos.
I have ordered SLA prints of all the parts which I plan on using for master to make casting molds for short run production.
How does everyone feel about crowd funding the production?
Jon – Solidus Labs
January 26, 2014 11:45AM
Here is a pretty good milestone. I'm printing one of the GDR pieces on the GDR. Repraping...
[www.youtube.com]
January 27, 2014 01:34PM
Hello Jon
How precise are the parts comming out of your machine? Are they usable as mechanic parts?
Thanks
A2
January 27, 2014 03:19PM
@SolidusLabs:
You have longer arms now, what is the size of the build envelope?
Can it accurately reproduce the arms, and worm wheel?
What is the print speed, and what do you think the top print speed will be after tuning the software, and calibration?
January 28, 2014 10:44PM
Guizmo
Hello Jon
How precise are the parts coming out of your machine? Are they usable as mechanic parts?
Thanks
The shoulder was fairly loose on the tolerances, it was probably 0.3 mm because of the low sub divisions. I was pushing the firmware pretty hard to get 16x microsteps and 50 sub divisions/sec at 60 mm/s. At this speed I was able to see some distortion on the faster curves.
The 16x microsteps works out to about .0037mm which is absurd. Setting the microsteps to 4x (.015) or 8x (0.0075) I can hike up the sub divisions to 200 and still maintain the higher speed.
The print fits into the upper arm after some reaming and cleanup so I think they are useable parts.
A2
@SolidusLabs:
I lowered the print head so the build envelope is approximately the same. 180mm diameter x ~100mm z useable. All of the GDR parts will fit in the build envelope.
I am printing the worm wheel now. I’m printing at .48 nozzle @ 150 micron layer height and about 30mm/s which will take about 4 hours. I normally print them with a .28 nozzle so we shall see how the teeth come out. I prefer slower and accurate instead of fast and have to print again. 60mm/s is printing now but I think I can get it up to 100mm/s
January 29, 2014 09:01PM
Yay parts. Enough for 2 more machines. Time to build some beta units!
A2
January 30, 2014 11:56AM
Components look great!
I'd like to see a video with all 3 running smoking smiley
Have you decided on what electronics that you will be using?
January 30, 2014 09:51PM
A2
I am running with ramps 1.4 but im interested in the ramps-fd
February 03, 2014 08:54PM
After printing about 20 calibration circles I'm about 97% there. I'm still dealing with some spherical issues from my base plate. My router needs a tuneup.
A2
February 04, 2014 02:04AM
@Solidus Labs:
It looks fantastic, I'm impressed, and it appears to be round, good job!thumbs up
It looks like a joint shifted to create the step in the worm wheel tooth profile.
Will the cast resin parts include the extruder?
The standard appears to be RAMPS 1.4, + Arduino Mega2560 R3.
The ramps-fd looks great, but I don't have experience with any of them.
